Question about MSI GEFORCE 7600GT PCI-E VGA 256MB Graphic Card
Capacitor Explosion/Replacement(?) Hi, my computer had a sudden crash. The computer was able to boot up, however, the monitor would not appear. I removed the Video Card (Geforce 7600GT) and noticed one of the capacitors(?): FZ71,1500 6.3V appeared to have cracked open on top. Please Help!
  • Sphynkter
    Sphynkter May 11, 2010
    Who is the manufacturer of this video card? For example, is this a PNY 7600GT? EVGA 7600GT?
  • 3,267 Answers
Try using the integrated display of the motherboard. If you get a display then as you mentioned that one of the the capacitors has overheated and cracked. Just replacing the capacitor does not guarantee repair because of the chain affect some other unots on that circuit might have conked out too........sodeep
Posted on May 11, 2009
Far cry 2 keeps crashing to blackscreen
When does this crashing or black screen happen? During the boot up process or while you have windows booted all the way up?
If the computer is booting up all the way except the screen is black try the steps below.
Either your monitor or video card inside the computer is bad. Try connecting another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without any problems then your video card is good, but your original monitor is bad. If the Borrowed monitor does not display then the video card inside the computer is bad.
If the computer is not booting up all the way then try the steps below.
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 07, 2012 | Computers & Internet
Hi, my asus f3sc display card crashed due to the fan problme i guess. When i was working, the screen suddenly went black, and it halted. Then i tried to start again. It's starting, but nothing comes on...
if the card crashed then the whole computer would crash, also if the graphics card has died the computer wouldn't boot into windows because it wouldn't pass the POST (Checks if RAM/Graphics card {as well as some other things} are working correctly before booting into windows)
sadly there is no way of replacing a dead graphics card in a notebook without a massive chance of destroying your motherboard, i'd recommend contacting the manufacter and find out if you are still inside warrenty to get a replacement.
Mar 20, 2011 | ASUS F3SC-AS127E-TM T7300/2.0/160/15/VBU...
Suddenly crash and cannot reboot
HI do you need my HELP please post
Sep 06, 2008 | Dell Inspiron 6000 Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
Moving line in LCD monitor
Just change the 4 capacitor near of the regulator area of the power supply...
that will fix your problem
Jan 16, 2008 | Acer Value Line AL1717B Monitor
Blurred Corners
hi there, its a decousing problem, look for the connection of the decousing which is connected behined the pic tube to the board. check some electronic parts, it may be temperature resistor, termistor, transistors, capacitor, etc.ty
Dec 25, 2007 | LG Studioworks 775N 17" CRT Monitor
Monitor
capacitor (either ceramic or electrolitic) that connect to vertical ic (TDA8173 or TDA 9302) is short or open. Check all capacitor in vertical range. tq
Nov 22, 2007 | IBM E74 17" CRT Monitor
Computers & Internet Logo
754 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
