Question about Garden
I have a 1996 721d grasshopper ztr mower. the right transmission slips nnot to bad foward but it wont hardly pull its self in reverse. any ideas how i can fix it without replacing the trans.
  • 3 Answers
There is a valve in the top of the trans that has unscrewed out of the hydro, your dealer has the special socket to put it back in the housing, There is one for forward and one for reverse in the gemini trans.
Posted on Aug 25, 2015
  • 61 Answers
Ck belt and tension pulley.
Posted on Sep 07, 2009
No foward or reverse
Lock under the mower, is a belt slipping or may has come off a pulley ?
Aug 19, 2016 | Husqvarna Garden
WONT GO FOWARD OR REVERSE
Not sure what all you checked but did you look at your drive belt? If it slipped of the pulley everything will still work just fine but it want move.
Aug 09, 2015 | Husqvarna Garden
I have a Toro mower made in 5/09 self propel system it grinds when you pull it in reverse. The selp propel is not working. The belt is on. and it seems to be only the left rear wheel? The cable is not...
Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
Jul 21, 2014 | Toro Lawn Mower. 22 in. Personal Pace with...
Ransom's bobcat ztr wont engage forward or reverse? Belt or hydraulics?
Check you hyd. engage and disconnect pin. Check belt may be slipping.
Mar 01, 2014 | Garden
My mower just stopped while mowing the other day. transmission barely holds drive and wont reverse at all.
Have you checked the belt? If it has bad spots on it or is stretched out , it should be replaced. Sounds like it's slipping on the pulleys and won't pull because of a bad belt. That's the first thing I'd check. The key on the crankshaft, (where the pulley is held on). It could also be sheared off and letting the pulley slip on the crankshaft and not pull.
Garcuda
Aug 03, 2013 | Craftsman Garden
Self propel always engaged
you may have lost the spring that pulls the transmission drive belt down or have the cable adjuster too tight.word of caution here, the cable goes thru the engagement lever and if you overtighten it the lever will crack or break. if it does the complete transmission will have to be replaced.seems they dont make the lever avalible seperate.
Jul 09, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Cub Cadet ZTR M60, left transmission slipping.
mostly all lawn equipment gear axles & engines run on sae 30 weight oil & it should be 1/2 to 3/4 full unless told other wise
Jun 05, 2009 | Garden
Hard to shifet my poulan pro and wont go into reverse
Try loosening the belt tension to the transmission a little bit. Some of these are just stiff and you have to slip the clutch a little to rock them into gear.
May 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Self propel will go foward, but will not reverse. Seems like handle is all the way extended.
There is a cable that connects to the handle and goes down to the powerdrive transmission. It is visible at the actuator arm on the drive if you look at the bottom of the handle where it pivots on the main housing. It will be on the right hand side, front corner of the handle bottom. You should be able to see the cable connected to the arm of the drive and will move back and forth with the top handle. Sometimes, they break at this connection. The cable may be frayed and broken, or the acuator arm may be broken where the cable connects.
This could also be a simple worn belt problem. The roller is always rotating in a direction that pulls the machine forward and if the belt is worn, the roller will turn sluggishly but still enough to pull forward, but the belt also drives the transmission and a worn belt will not have the capacity to overcome the forces involved to propel the machine backwards. Always change the belt(s) yearly.(on average)
Dec 22, 2007 | Hoover U6630-900 WindTunnel Bagless...
Garden Logo
758 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
