Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
No lamp or sound
Tv is about 2 years old? when you turn on the power button the lamp light blinks for 30 seconds or so but never lights up. no sound . then the set powers down. same sequence each time. no light no sound
  • 105 Answers
Check your lamp..
Posted on Oct 14, 2007
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
Mar 15, 2009 | Sony KDF-E502000 50" HDTV
Won't turn on. Green power light blinks for 30 seconds and then red lamp light blinks constantly
If the lamp light is lit, it is likely a bad lamp. If you remove the lamp from the set, you will either see shards of glass in the housing and/or a very cloudy reflector (it should look like a mirror). Be sure to use an original Sony lamp as the replacements are trouble makers. Please be sure to rate this solution. Thanks!
Oct 29, 2008 | Sony KDS-60A2000 60" HDTV
Dead sony
The $1200 was for the lcd engine not the lamp. You should change the lamp. The buzz is the power supply trying to light the lamp.
Apr 25, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony kdfe55a 20
2 YEAR IS TIME TO RPLECE LAMP
Mar 30, 2008 | Sony KDF-E55A20 55 in. LCD Television
Turn on and Power and Lamp Lights blink.
Just because it doesn't look broken doesn't mean it hasn't failed.
Is the TV over 2 years old?
If so, buy just the bulb (not the whole lamp assy) from us at sedonix.com, install it yourself and save about 75% of what Mitsubishi charges.
Dec 13, 2007 | Panasonic PT-43LC14 43" Rear Projection...
TV will not turn on.
This is usually caused by 1 of 2 things.
1: You have a lot of dust in the vents so the bulb gets too hot. You might see a flashing red temperature light on the front status button. Clean the vents to the light housing and see if that solves the problem. You might also want to physically disconnect the power from the TV for about 30 seconds to allow it to reset if it is just a random problem.
2: Your light is about to go out. If you have had the tv for a few years, it is possibly time to replace the light bulb. You can usually tell this because the light will be dimmer than normal and possibly all 3 indicator lights will be blinking on the status button on the front.
HTH
Mar 07, 2007 | Samsung DLP HL-P5663W 56" TV
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
