Harman Kardon HK206 Computer Speakers Logo
Posted on Oct 13, 2007
HK206 SPEAKERS WITH USB PLUG
I HAVE A DELL COMPUTER WITH A PENTIUM 3 AND HARMAN/KARDON HK 206 SPEAKERS. THE SPEAKERS HAVE A USB PLUG. ALL I GET IS HUMMING. CAN ANYONE HELP?
  • bebo63 Oct 15, 2007
    Thanks for your suggestions. I bought the whole computer from work for $50.00. I talked to them and they said that I can just exchange the speakers for another set with a regular plug on them. (I already tried another set and they worked).
  • Anonymous Mar 23, 2014
    How to replace
A
Anonymous
Have you plugged anything else in to make sure the usb port is working? does the computer recognize the usb speakers when you plug the usb plug into the computer? do the speakers work on another computer? if you wiggle the usb wires around does it make a sound through the speakers? eliminate these questions so that we can move on to isolating the issue.
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Will Harman Kardon HK 206 speakers work with Dell Inspiration 560 with Windows 7 and if so how do you hook them up and install
since they are stereo they should have not issue. just connect the 3.5mm jack to your output port typically the green audio jack.
The icon for my Harman Kardon speakers completely disappeared from my desktop. No there is absolutely no sound
Are the speakers plugged in, turned on?
Restart the PC.
Unplug the speakers from the PC and plug them back in.
Unplug the power from the speakers and plug them back in.
Need driver for my harman/kardon HK206. Unable to get sound...
If you are unable to get sound from speakers, chances are it's your computer and not the speakers. Speakers do not require a driver to work, the computer has to have the audio driver to make speakers work. To test this theory, simply turn speakers on and plug them into an mp3 player or cell phone (anything with 3.5 mm jack) and turn volume up - should have sound. What you will need to do is find model computer and look for audio driver for that computer.
I have a harman/kardon class 2 transformer model# 661520oo3ct. It was with my computer equipment but not hooked up. I don't remember what it was for. what uses does it have?
hi,
it comes with ur desktop speaker harman kardon hk 206. it is a 12v 1A dc power supply. u can use it in any equipment which needs that power rating. only thing to remember is, check the polarity of both before connecting.
ok
2helpful
HK 206 What size transformer does it take? 9v, 12v??
Original wall transformer is 12Vdc 1000mA current
Imput voltage depend of your country
HK206 speakers - bought a 2nd hand set - power plug doesn't fit
Try Radio Shack. They have adapters for just about every style of audio jack.
1helpful
Harman Kardon HK206 Speakers
driver-updates.net
It sounds like free but check it out first
aslo check out dell
No sound
Your HK speakers are special and don't need any drivers, just plug it into the Audio jack of your new system and you should be able to blast away to glory! :)
Lemme know if this helps!
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Sean Wright
Sean Wright
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
