Question about Invacare Pronto M51 Power Wheelchair
Steering knob on the wheelchair steering knob came loose and is about to come out.
The steering knob on the motor wheelchair came loose and it's about to come off.
  • 175 Answers
Don't use superglue! If the boot that covers the joystick rips and needs replacing, you have to take that know off to do so. Use rubber cement, which will come lose with a good pull.
Posted on Jul 07, 2009
  • 103 Answers
Super glue
Posted on May 26, 2009
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
Jun 16, 2015 | Invacare Pronto M51 Power Wheelchair
Jazzy 1113
check wiring and pcb in your chair...it may be loose connection in between the path
Sep 30, 2008 | Pride Jazzy 1113 ATS Indoor Power...
I have a quantam 6000z wheelchair,all of a sudden it wont work and reads motor 1 disconnected#192.what can I do im desperate
Sounds as though one of your motor/servo connections has come loose. Here is a manual for the chair. http://www.manualslib.com/manual/134605/Pride-Mobility-6000z-3mp.html#manual
You might wish to check out page 19 of the manual where it describes in fair detail where the connections are and how to reset the breaker.
Nov 23, 2014 | Health & Beauty
Power steering electric
If the chair wants to drive left then you have a disengaged left motor clutch lever or a left motor going bad. Then M51 will not give an error code if the clutch is disengaged. If the chair is veering left as you are driving but you are still able to turn to turn right then the motor is not likely to be disengaged but has a brush or gear problem.
It is also possible that the joystick is not working well. The joystick is much less likely to be the problem unless it is damaged somehow.
Sep 02, 2014 | Invacare Pronto M51 Power Wheelchair
My Power-steering is hard to turn
check power steering fluid level, check for loose power steering drive belt, if this are ok there could be problem with power steering pump.
Dec 18, 2013 | Cars & Trucks
Wouldn't run, blcking 2 light
Joe you don't give much info but 2 lights indicates left motor disconnected. Check the cable to the motor to make sure it didn't come loose from the controller Hope this helps
Oct 11, 2010 | Quickie Wheelchairs Quickie Wheelchair 18"...
My friend has a rascal electric wheelchair he rode it here andveven tho we put the charger on--and he recently spent $200 on new batteries--it wont move the horn honks and it appears charged but it wont...
Hi. This type of fault can be caused by a few different problems. Is the machine flashing any fault codes?
Faults could be a stuck brush in the motor, Free-wheel lever in the wrong position, faulty motor or battery connectors, loose battery terminals, jambed brake solenoid.
Hope this helps. Neil.
Jun 09, 2010 | Pride New Jazzy 600 Power Wheelchair by...
Speed control knob has come off
you need Invacare part # 1040225, cost about $6.00. Call these people 866-722-4581
Sep 21, 2009 | Invacare Pronto M51 Power Wheelchair
Invacare Pronto M51 Power Wheelchair Logo
170 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
