Question about Dryers
My dryer is very load when it is running like a rubbing sound
  • 460 Answers
I need the serial # but let me see if this works If is a Kenmore
copy n paste
http://www.youtube.com/watch?v=S5hVeShxLkc
was this helpful?
Posted on May 13, 2009
Frigidaire dryer started making load noise when motor is running
Hello - Is it a rubbing or thumping noise? If so, it sounds like the tub could possibly be unbalanced from either a bearing/pulley suspension problem or the unit has broken something off in between the tub and outer portion of the unit. This is not a typical DIY job since the entire back panel of the unit needs to be pulled off and diagnosed. Contact a professional to move forward accurately.
Jan 02, 2013 | Frigidaire Dryers
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Amana ned7200 heater element changed out, now runs rough
Sounds like one of the rollers is not lining up. I would get the tech back out there.
Nov 21, 2012 | Amana 7.1 cu. ft. Electric Dryer - NED7200
My gas dryer has started making a metallic screeching sound after its been running for a bit. Its coming from the rear of the dryer. I'm concerned that it might be the motor. It kind of comes and goes and...
Could have been that the alignment is out of way andis rubbing on when in a particular direction or with the load.
As you have observed the motor could be the issue , it will be good to open and look for the movement of the motor.
The suspensions can be a little out of alignment . also place the dryer in a level postion.
Check for uneven running due to any friction of the drive. If so it can agitate and make it rub on the sides.
Aug 31, 2010 | Dryers
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
I have a rubbing sound each time the drum turns in my Maytag Neptune dryer
Run the dryer empty, if you still hear the sound but not as loud as when loaded, the bearing to the drum are shot. Either way, I think the bearings are bad. They are permanently lubricated, so ther is no greasing them.
Dec 24, 2009 | Dryers
Sounds like the tub is rubbing against something
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
When you have the drum out you can check for rub marks on the drum also.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 09, 2009 | Maytag Dryers
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
Lg dryer - front load - making a grinding noise
I also have the same problem as klrlesimmons, exactly as described. Sounds like sand is rubbing as the drum turns, and also sounds out of balance.
Repairmen replaced upper and lower glides and also the plastic bearing but not the entire bearing assembly.
Frigidaire Gallery, Model Number 417.49012890
Mar 22, 2009 | LG DLE3777 Electric Dryer
Kenmore front load dryer rubbing noise
What I found with my rubbing noise was very small rocks that past the felt ring and became traped between the felt and the steel drum. I will have to pull front cover off to see if I can get to it.
Mar 15, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
