Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Cant find serial plate.
Where is the serial plate on my tb525cs line trimmer?
  • 246 Answers
Hello brascr96:
Depending on its Location it May be Covered in Dust/Dirt.
>>Generally the identification tag is on a part of the unit that, even after years of use, rarely needs replacement. For most of MTD (includes Troy Bilt) power equipment, these tags are approximately 2" by 3" in size. They also have the MTD Products name, address and customer service phone number listed across the bottom. For hand held product, the tag is normally white and approximately 1" by 1/2" in size. Hand held i.d. tags are normally on an aluminum portion of the engine, somewhat set into the unit to protect the label from wear. (A bar code will also be on this tag.) Riding mower tags are located on the underside of the seat. For walk behind mowers this tag is found either on the deck or on the rear door of rear discharge units. Tiller model and serial tags are generally on the tine housing. **The model and serial tags for two-stage snow throwers are located on the bottom of the main gear housing which is often called the belly pan, while single stage snow thrower tags are next to the key and primer. For other products like log splitters, chipper shredders and edgers, tags can be found on the frame or main housing.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
Remove the clutch on a TB525CS trimmer
It is generally CCW. Look on the clutch itself, sometimes there is an arrow covered up in goo.
Sep 27, 2014 | Troy Garden
How to change trimmer ine in tb525cs - troy built 4 cycle trimmer
You need to unscrew the black bumper button. I believe it is counter-clockwise. Mine was very tight and took a pair of channel lock pliers to loosen.
Jun 21, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
What size string do i need it is a tb525cs
Probably .065 to 080 line will probably do the trick .A line with 3 or 4 edges works great on everything
Oct 21, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt TB525CS Line Keeps Being Sucked into Housing
You may have wound the line in the wrong direction. Check it out. We all do it at least once...Lee
Sep 09, 2009 | Garden
I need a manual for TB525CS, showing parts
In your search bar type in JUST the model number NOT the manufacturer. Beside this type "pdf." and the word "manual" You'll get a lot of sponsored sites, after that watch for the ones with your Manufacturers name in the URL.
Aug 16, 2009 | Garden
Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
The starter line on my trimmer will not pull at all.
Remove spark plug to see if problem is in engine or drive unit
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
Line replacement on Troy-Bilt TB525CS trimmer
This was my problem as well when I initially purchased. After letting it sit for a week due to frustration...I tried again. I believe that the manual is wrong when it states that the winding is clockwise and could cause the teeth to eventually wear down. I watched the motion of the speed spool when I gently tugged on the line simulating the centrifugal force...there is no way that you can wind it clockwise and expect it to stay. I simply wound it COUNTER-CLOCKWISE to get the desired result. I finished trimming the lawn and had no more problems...except for learning that I cannot edge along concrete without the line wearing quickly.
May 08, 2009 | Mtd Garden
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
122 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
