Question about Serif PagePlus 8 PDF edition for PC
Does not open with vista
Have page plus 8 pdf edition disc. has worked fine with XP. Have loaded disc on to new laptop with vista. Program advised me to update from adobe reader 7 which I did to v9 successfully. Was also advised PP* had loaded successfully. However when opening ppp8 only a greyed out window appears and now welcome or wizard screen opens. The programme then stops responding and has to be closed down. What have I done wrong or is there a fix/patch I need from somewhere. Thanks for any help you can give Regards Alan
Find the pageplus.exe in the installation folder, c:\program files\serif\pageplus\program
right click it and the select the compatibility tab, click change sttings for all users, tick the box "run as administrator"
Posted on Sep 24, 2009
  • lioash Sep 24, 2009
    if its the 64 bit version the installation folder is
    c:\program files (x86)\serif\pageplus\program
I have had my compaq laptop windows xp home edition since 2002.windows now tell me it is not verified authentic,after long conversations and emails with them they say I have windows proffesional 2002...
you can obtain a disk easy enough there's plenty of boot legg copys floating around as bad as i hate to say it... but there is a trick to this matter.
find a computer that has xp on it and copy the key gen/code/serial numbers off the sticker then put then in your system to regrister your copy it will except that just fine and no more worry's
Jan 13, 2010 | Computers & Internet
HP 4470c flatbed
If you can get the software onto your computer, try right clicking on the scanner program--properties--compatability tab--check "run this program in Xp compatability". Worked for me in Vista
Jul 06, 2009 | HP Scanjet 4470c Flatbed Scanner
Boot Disc's Not reading, Dvd rom help? or Xp/vista help?
How did you made it boot to the disc? if you used keystrokes to do so, it would be better if you go into your BIOS and set the boot priority making the dvd drive as priority and see if it is gonna work that way. If it does'nt you need to be concerned about the drive itself, it might be having problems as well.
Jun 02, 2009 | Sony VAIO VGN-S480B PC Notebook
.pdf files in adobe reader 8.0
Hi Jim,
While I can't tell you why adobe 8 wants to save files before reading or printing, I can suggest that you try again to go to:
control panel in XP
add/remove programs
pick adobe 8 and uninstall it
If you still have the older version installed try to see if it works now. You may need to restart pc to get it working.
If not then uninstall all versions or READER you may have.
Restart computer.
Now go to ADOBE.COM and install VERSION 9, the latest, and try it out. Its best to go directly to the site from your browser rather than follow links of dubious origins.
If it STILL won't work right for you, then try the following.
Go to the link below and install the older version of READER that you liked. Its a fine website with OLDER versions of many programs.
http://oldversion.com/program.php?n=acrobat
Good luck Jim, and I beg you please don't vote for me unless I was able to FIXYA!
Thanks.
Jan 07, 2009 | Microsoft Windows XP Home Edition
I cannot load Pagemaker 6.5 onto my laptop w/ Vista
Pagemaker 6.5 is designed to be used with Windows 95 / 98 / NT 4, therefore in order to run it in Vista I'd suggest to run your Pagemaker 6.5 using Compatinity Mode --> Go to your Desktop --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
Nov 08, 2008 | Adobe PageMaker Plus 6.5 for PC
Nero 8.0 and vista
Reinstall the nero 8 and restart the system. If problem persists then it is better to change the OS to windows XP SP2.
Oct 28, 2008 | Microsoft Windows Vista Ultimate Edition
Canon 20D Camera & Vista
it's probably the Canon EOS 20D
go to http://software.canon-europe.com/products/0010131.asp and select windows vista
it's only available for windows vista 32 bit, so it probably doesn't work if you have the 64 bit version
Jun 11, 2008 | Microsoft Windows Vista Ultimate Edition
Downloading photos from Canon 400D direct to Canons photo editing programmes on new windows Vista computer.
There are two ways to solve this problem. I am assuming you are simply clicking on the pictures and choosing "edit" or double clicking on the pictures and they are opening in "Vista picture editing"
The first way to overcome this is by opening the desired program first (in this case canon's photo editor) and then choose open and find the desired photos.
The other way is to set the file type association in vista so that RAW programs open with the canon program see below for step by step:
1. Click Start
2. Click default programs on the black bar
3. Click Associate a file type or protocol with a program
4. Find the file types you want to open automatically in your canon editing program (RAW .jpg etc)
5. Click once at the top of the page click change program
6. A new window will open, if it does not list the correct program click browse at the bottom of the window and find your editor in it's folder.
7. Select the desired program by double clicking
8. Click OK
9. Click close
10. Test the new file association by double clicking a RAW file or one of the other file types and see if it loads into the correct program.
The final (and this is simply my plug for open source programs) solution would be to try something like GIMP (it is a photo editing suite developed under linux but adapted for windows) you can search for it on google.
If you are having trouble with any of these steps please post a comment and I will try and add some clarification.
Hope this helps
May 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Optiarc CD-RW CRX880A
You need to edit your registry.
Click the Start button, click run, type in the run window regedit than click OK
Close any opend Keys. Open HKEY_LOCAL_MACHINE than open SYSTEM next open CURRENTCONTROLSET than open CONTROL than open CLASS & find
{4D36E965-E325-11CE-BFC1-08002BE10318} listed in the right half of the window right click on LOWERFILTERS & left click delete, then right click on UPPERFILTERS & left click delete.
Exit the registry, and reboot the laptop.
Good luck.
Mar 11, 2008 | Microsoft Windows Vista Ultimate Edition
Serif PagePlus 8 PDF edition for PC Logo
376 people viewed this question
Top Serif Computers & Internet Experts
Martin Murray
Jax Planet
Jax Planet
 Grubhead
Grubhead
Are you a Serif Computer and Internet Expert? Answer questions, earn points and help others
