Power surge knocked out my laptop. Now it only starts up for 10 seconds and shuts off again. How can I replace the motherboard?
  • 4 more comments
  • frshstrt55 May 11, 2009
    a laptop
    wow, you just talked a foreign language to me! I dont know anything about heat sink the fan is still working.
    ok, I will try that right now. thank you.
    I removed the battery, and hooked up the power cord. It began to open, got as far as the Windows logo screen and shut off again :(
    thanks. I will try it. Best Buy Geek quoted me $500 - 600 to fix it!
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    Is this a laptop or a desktop motherboard?
  • 3,267 Answers
The processor is overheating causing auto shut down to prevent damage(further). Get the heat sink & if required apply fresh heat conducting paste between the processor & heatsink(if the fan is still working). Also the power supply inside the PC might not be delivering the correct voltage(3 different voltages), which will require relacement..................sodeep
Posted on May 11, 2009
  • 4,806 Answers
Hi again.
Try taking the battery out and use AC power only, if the laptop boots up then the surge has knoked out the battery and it will need to be replaced.
Please post back with the results and thanks for using FixYa!!
  • Lee Hodgson
    Lee Hodgson May 11, 2009
    Hi there.
    The PC is overheating, get a can of compressed air and give short blasts through the air vents, once you are happy that all the dust is gone try boot the machine up again and it should stay on for longer.
    Good luck
  • Lee Hodgson
    I doubt that the motherboard is damage and the qoute you have have got is rediculous the fact that the PC still boots up is a clear indication of that, just follow the advice and clean the dust from the machine and it should work fine, you may however have to buy a new battery.
    Good luck
My system is password locked and I cannot remember the bios password
You cannot bypass the password security yourself. If you could there would be no point in having password security on all our devices.
Jan 13, 2016 | Computers & Internet
Mother board heats up and computer does not start
Does it start up at all ? Will it start up in Safe mode ?
Heat will cause computer components to expand sometimes not being able to make connecting to the hard drive. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ Motherboards can go bad for many reasons, although there are a few common culprits. Among the most common causes of motherboard failure are excess electrical shocks, physical damage, or excess heat. Some of these dangers are inescapable, and may vary in likelihood depending on your computer model. Fortunately, there are some simple steps to protecting the computer's motherboard, or mainboard, as it might also be called.
Signs of a Failing Motherboard Detecting the difference between a failing or failed motherboard and other failing components can be difficult. This difficulty arises because all the components of a computer are plugged into the motherboard. Thus, if you are having trouble seeing the screen, it could be that the motherboard is failing or that the video card is failing. For this reason, any part of the computer failing can be a sign of a motherboard failure. However, there are some more specific indications that the failure is the motherboard. These include the system randomly powering down, all the components of the computer powering up without a live image appearing on the screen and only certain components of the motherboard working. b> Causes of a Failing Motherboard b> As with most computer components, the most common culprit when a motherboard fails is heat. All computer components are particularly sensitive to heat, and the inside of computer can become quite hot. Over time, this wears out the motherboard and can lead to its failure. A second common cause of motherboard failure is electrical damage. Commonly this occurs during computer maintenance such as installation of new peripheral devices. During maintenance, if the technician has static electricity built up on his or her hands, it can discharge into the motherboard, leading to a failure. Electrical surges, such as those created by lightning striking a power line, can also lead to motherboard failure. This is most commonly prevented by using a surge protector, but some surges are powerful enough to overpower the surge protector and destroy the motherboard. The last common cause of motherboard failure is physical damage. This can be in the form of water damage or actual physical impact. Although the motherboard is typically well protected, a strong enough hit to the computer case or the introduction of water into the case can lead to motherboard failure. b> Diagnosing Motherboard Failure b> Determining that the motherboard is the cause of a particular symptom can be difficult. Although specialized tools exist to determine if a specific component has failed, the easiest method for determining which components are damaged is a simple bench test. This does, however, require having a second computer, or at least extra components. The method for this is to determine what possible causes could lead to the symptoms of motherboard failure. For example, if the system shuts down randomly, it could be the motherboard, the power supply unit, or connecting cables. In this case, you could plug the power supply unit into another system that is known to be working and if the problem persists on the other system, then the power supply unit is the likely cause of system instability. Similarly, if the computer powers up but fails to display an active screen, you can move the video card into a second, working computer and determine if the video card is bad. Then try using the good video card from the second computer in the damaged computer to determine if it is only the video card or if it is also the motherboard. Although this method is not foolproof, it is effective. b> Preventing Motherboard Failure b> A few simple steps can be taken to ensure the motherboard does not fail. While a motherboard may fail anyway, simply due to age or unforeseen circumstances, it is less likely to fail if you take a few simple precautions. First, ensure the computer is in a stable location where it will not be knocked over and will not be likely to have liquid spilled on it. Second, if any maintenance is performed that will expose the motherboard, use an antistatic wrist strap or discharge any static electricity before working in the computer by touching a grounded metal object. Third, keeping the motherboard clean and free of dust can ensure that it continues working, although some computer manufacturers do not allow the users to open the case during the warranty period. Last, ensuring you use a quality surge protector can prevent the motherboard from being destroyed by power surges. b> Laptops Laptop motherboards are more exposed to damage than desktop motherboards. Although they tend to stay cleaner, they are more likely to be exposed to heat due to the small case. They are also more likely to be exposed to impact since the computer is being regularly moved. When transporting a laptop, it is crucial to use a case designed for laptops that will prevent blunt forces from hitting the laptop. Also, many laptops have vents on the back and the bottom. As cooling the inside of a laptop is much more difficult given the confined space, ensuring that these remain unblocked while working on the laptop is critical. Learn where they are on your laptop and ensure you leave them unblocked while working and the laptop's motherboard should be effectively cooled. Hope this helps.
b>
Dec 24, 2012 | Computers & Internet
Shut down in sleepmode by mistake, how to awaken?
Press enter twice or press power button to awake.
Thanks,
satheesh
Jan 20, 2011 | Computers & Internet
I HAVE BEEN TOLD THE MOTHERBOARD HAS COME UNSODDERED FROM "SOMETHING". I HAVE TO HOLD THE POWER JACK AT A CERTAIN ANGLE TO BE ABLE TO START THE LAPTOP UP, THEN IT WILL SHUT DOWN AFTER 10 SECONDS. CAN...
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 15, 2010 | Toshiba Satellite A75-S211 Notebook
I plug in the power supply the notebook doesnt power up but the green light on the supplier goes off?
Unplug the notebook, take out the battery.
Hold down the power button for 10 seconds
Now replug in your notebook
If it powers on, then the unit suffered a minor surge and you should from this point use a surge protector from now on.
If it does not power on, then the unit suffered a severe power surge and now the motherboard is blown and needs replacing or buy a new notebook.
Mar 16, 2010 | Dell Latitude D600 Notebook
Is the mother board fused to protect it from any surges or power spikes?
HI rstrstx2,
No I'm sorry motherboards are not fused. They are pretty resilent thou.
A few power spikes and surges shouldn't knock you out. However, if the surge was large enough to shut to system down, then you may have problems. Anytime someone removes or touch's a motherboard they are suppose to be wearing anti static wrist wrap's to protect the board from static.
Hope this answer's your question
Thanks
Mark
Mar 12, 2010 | Toshiba Satellite M115-S3094 Notebook
I think the motherboard is shot
It Can Be One Of Two Things Your Motherboard Was Fried Or Your Battery Was Fried Have You Tryed Buying A New Battery?. If Not I Recommend Buying A Battery And If The Problem Persists You'll Know Its The Motherboard For Sure, And Theres Two Ways You Can Go About The Motherboard Buy A New One And Install It Yourself With The Correct Guide Or Have The Laptop Serviced. Hope This Is Of Some Help
May 11, 2009 | Compaq Computers & Internet
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
HP nc8000 shuts down after 10 seconds
try pushing on the upper right corner of your laptop, above the home key, does it start up again?
If so its the maxim chip
if not take one so dimm out and dissable wireless.
Could also be your battery not charging because a battery or power cord malfunction.
Oct 21, 2008 | HP Business Notebook NC8000
Laptop fails to start
bad mobo do u ever use it on your bed overheating died kiled power chips on mobo best to get new one mobo or sell on ebay its 1 yr warenty call maker
Jan 24, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
