Question about Refrigerators
My frig/freezer repairman needs a wiring diagram. I have the model, ser no and type to give you. I also need to know the age of this unit.
    Guru:
  • 1,524 Answers
So display the information
Posted on May 12, 2009
Frigidaire frig. model#FGHC2331PF7 is dripping onto top shelf and the filter has ice cycles and what temp should freezer and frig be
If it's brand new and leaking, call the place you bought it from and have them fix it. As for the temp settings; there is a center default in the freezer and you should start there, the fridge also has a default which should be OK. If you need it colder turn it up in small increments and give it a day before you make any additional adjustments. The "cold" in a fridge or freezer also depends on how much stuff you have in the unit, and how often you have the door open.
Sep 08, 2014 | Refrigerators
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
What year was model number 253. 54622402 built? Freezer is not getting cold enough is it worth fixing?
can;t help with sears model # for age but do ck the model # plate for the type of coolent like R 12 or R 134 / if its 12 i would replace frig .. the poor cooling on any frig may be caused by dirty coils or fan motor blowing over the coils . clean them and ck that fan is going . ther is also a fan in freezer that may have quit so ck that one also . mm hope this helps .. feeed back pls .. mm
Sep 18, 2011 | Kenmore Side by Side Refrigerator
Freezing compartment stopped operating. Heard motor struggling, then stopped. Frost had gathered at the back wall of the freezer to over 1/2 inch thick. Refrigerator side also gave out cooling. Cleaned...
Hi, What you are having is a defrost problem. You will need a defrost timer or on newer models the control board, also the defrost heater and the termination thermostat. You will need your complete make and model number to get the parts from a local supply house. You will need to unplug the machine. The back wall of the freezer needs to be removed. Use a blow dryer to get rid of ice buildup. Install parts. Timer is probably in the frig compartment or the board on newer models on back of frig. Hope this helps
Jan 18, 2011 | GE Refrigerators
Tried to adjust temp of refrigerator and the panel went crazy, flashing through the various settings. Not sure what to do.
need a model # and ser # off the machine itself to give correct ans and part that has failed .. this is what i think . your machine uses a prosser with sensors and the prosser has failed . this can cause the flashing and how knows what . some models the ice mker will keep opening the ice door and never quit and the flashing controls . . to correct you will need to replace the controls in the frig side .. mm / hope this helps . mm
Nov 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our frig ice cube door chute keeps slaming and the lights are going crazy on the push button board. model MFI2568AES SER 10967637JR
Your control board is bad. Unplug refrigerator and replace it, follow instructions on board to reprogram and you should be good. It's on the back outside of refrigerator under panel. Or, call a repairman to do it for 400.00 plus. Hope this helps,
Oct 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Hello. I have a Frigidaire Gallery refrigerator. model is FRT22RGCW7 (which i can't find on this website). it was made in May '98. the refrigerator portion recently got exremely cold. freezer...
I used your model # and it came up on frig web sight . but they do not give age to these # only parts info . the age would only be avlb to dealers . i know this didn't ans your question but that info is not avilb. .. sorry mm
Oct 16, 2010 | Frigidaire Gallery Series® GLHT188WH Top...
Would like to replace need to know size of unit and age.
this unit is a 3 1/2 unit...the 42 the model number...possible its a 89 or 97 model...this is a 42,000 btus unit...hope this helps...michael 843-384-8474..
Mar 27, 2010 | Heating & Cooling
PLHS69EGSS1 Freezer not cooling properly but Frig is OK
This is one time you might need gas. Your freezer needs to be 20 degrees or less for the ice maker to work.
May 01, 2009 | Frigidaire PLHS69EGSS Stainless Steel Side...
Have 16 yr old Kenmore model 106.9537622. The heater strip at the center divider between freezer and frig gets real hot for a period of time everyday and causing frig and freezer to be too warm. The...
if this is a side by side refrigerator, then the space between the doors is not heated by an electric heater. it is heated by part of the condensing coil. so the excess heat is probably generated by a loss of adequate airflow under the machine. which would explain the temperature change in the refrigerator.
  • clean the coils under the machine and make sure the fan is working.
  • make sure the airflow is not obstructed in any way.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 01, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
