Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
Thermador oven overheating
My Thermador oven (model PRDS364GD) seems to be overheating anything and everything! First I thought it was because I'd used the convection feature, but now I set it simply to "bake" and watched it destroy my beautiful French lemon tart. Doesn't matter how low I set the dial, this baby annihilates everything! What to do? I did spot a note in the manual where users are instructed not to overshoot their desired temp as the dial can not then be set lower, but must be returned to "0" and set again. Any input would be appreciated.
catriver
  • 878 Answers
SOURCE: Jenn Air wall oven-Broiler element comes on and will not turn off....
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
Posted on Apr 10, 2007
  • 1314 Answers
SOURCE: jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Posted on Dec 29, 2007
docjohn174
  • 943 Answers
SOURCE: Jenn_Air Oven Problem
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
barkencoa
  • 3463 Answers
SOURCE: Fan Oven cooks at high temp when on any setting
Sounds like main oven stat is faulty.
Is the stat sensor fixed properly inside the oven?
Could have been disturbed when element fitted
Please leave feed back.
Thanks
Posted on Nov 25, 2008
kram26
  • 544 Answers
SOURCE: I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Posted on Feb 19, 2009
Can I download a manual for a Thermador Professional oven?
Hi Donna,
Yes you can! Click on the link below and under 'ovens' select your oven's model type.
www.thermador.com/trade/specifications-guides
Hope this helps.Thanks!
Jan 06, 2012 | Thermador Ovens
I'M LOOKING PART OF THIS MODEL Thermador SCD302TP
Hello, welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door seal for your SCD302 series Thermador double wall oven. They should have anything you need.
http://www.repairclinic.com/Model-SCD302TP-ID-642642-Parts
Thank you for choosing FixYa and good luck. Please take a moment before leaving to rate the assistance provided here and your experience at FixYa.
Regards,
Macmarkus :)
Sep 19, 2011 | Thermador SC302T Electric Double Oven
Thermador 30" wall oven.
Your touch in put key is stuck, replace ,power relay board and the touch panel
Always unplug the oven first before service
May 20, 2011 | Thermador C301U Electric Single Oven
How do i self clean
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following products. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of Product: Thermador� Built-In Ovens
Units: About 37,000 (42,000 built-in ovens were previously recalled in June 2007)
Manufacturer: BSH Home Appliances Corp., of Huntington Beach, Calif.
Hazard: The ovens can have gaps in the insulation where overheating can occur and when used in the self-cleaning mode it can cause nearby cabinets to catch fire. This poses a fire hazard to consumers.
Incidents/Injuries: BSH Home Appliances has received three additional reports of incidents, including two that resulted in fires that damaged surrounding cabinets. No injuries have been reported.
Description: The recall involves Thermador Brand built-in double ovens with model numbers C272B, C302B, SEC272,C301U, SEC302, SECD272 and SECD302 and serial numbers between FD8403 through FD8701. Model and serial numbers are located on the underside of the control panel.
Sold at: Appliance and specialty stores nationwide from June 2004 through July 2007 for between $3,000 and $4,400.
Manufactured in: United States
Remedy: Consumers should immediately stop using the oven�s self-cleaning mode and contact the firm to schedule an inspection and free repair, if necessary.
Consumer Contact: For additional information, contact Thermador at (800) 701-5230 24 hours/day, 7 days/week, or visit the firm�s Web site at www.thermador.com
Dec 05, 2010 | Thermador C301U Electric Single Oven
My thermador double oven does not turn off for 30 minutes.
Welcome to FixYa.
Please clarify if I`ve misunderstood what you`re asking, but with all Thermador ranges and wall ovens ( including your SC302T model, most brands in fact ) the cooling fans will remain on for quite some time after actually shutting the oven off.
This is done by design to keep the electronics cooled to a temperature usually below 200°F so they aren`t damaged.
Heat after all is the thing which damages electronics more than anything else.
I do have use and care guides available via email attachments in "pdf" if you need one.
Thank you for choosing FixYa. I hope this eases your concern. Please let me know.
Regards,
Macmarkus :)
Sep 07, 2010 | Thermador SC302T Electric Double Oven
Reassembling thermador Thermatronic II lower oven door cmt21
you can use some of the glass of the old oven just need the size of the glass if you order from the manufacturing it very exp
Jan 03, 2010 | Thermador SMW272 Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Thermador oven parts
I have a Thermador oven where the inside window glass is broken. Are there any parts available for a
model #14-33-754
30 "?
kellythompson@frontiernet.net
Oct 23, 2008 | Thermador Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
205 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
