SOURCE: I have a 2007 Dodge Grand Caravan and the right
Usually that fast blink is a good warning that one of the signals is out. Double checked that bulb is same # and all that ? What number is on the bulb? if it's 2057 or 3057, try pulling wires on side of bulb with fingernail, outward to make better contact, to see if that helps.
Sounds like you have a bad ground. Follow the wiring harnesses under the hood and in the trunk, there should be a ground wire going to the chassis or to the body. If they are all clean and tight, you might be looking at a bad light socket.
SOURCE: my dodge caravan 1999 left turn signal wont work
Check the wiring behind it. If the insulation is cracked and a bare wire is touching metal, it can cause it to ground out which will result in what you see. Likewise, if there was a short in the wiring and the casings melted together (multiple wires touching), it will do this.
SOURCE: I have a 2006 dodge
The fuse for the turn signals is located in the interior fuse panel, usually located under the dash on the drivers side although it may be behind a panel on the side of the dash on the drivers side that you can access when the door is open. The flasher relay is located on or near that fuse panel as well. There is only 1 fuse for the turn signals so if you have some of them but not all of them it's not the fuse. It may still be the relay but I doubt it. That bulb may not look burned but it most likely is. that fast blinking on the right rear is an indicator that the front bulb is burned or not functioning. It is an indicator dodge built into there lighting systems. Replace the bulb, if that doesn't resolve the problem start check the wiring and look for a grounded wire.
