Question about Acer X193WBD Monitor
Acer monitor x193w, no sound.
I've just bought a new acer pc and monitor had no problem connecting it and everything is working but there's just no sound.The volume is up to full and you can see the equaliser moving up and down , just no sound.
  • munyaradzi muzividzi May 31, 2009
    looked into your solution got into my computer etc, and everything was fine there but still no sound??
    Sergeant:
    Champion:
  • 225 Answers
Please try to check the sound device status if its working properly thru right click My Computer icon > Properties > Hardware tab > Device Manager > (double click) Sound, Video & Game Controller OR System Device > System Speaker. also, take note of the Troubleshoot tab. If still it doesn't work, I think you have to reinstall the sound driver (from its motherboard software CD if it's built-in type). best regards
Posted on May 12, 2009
My Acer X193w. My monitor comes on and says cable not connected but when I connect the VGA cable the screen goes black even though it is still on.
VGA is an analog connection, so you should connect it to your monitor BEFORE starting up the PC. Otherwise it won't show anything
May 04, 2011 | Acer X193W LCD Monitor
What will show on the screen if you connect lcd acer x193w only electricity? (Without the PC you plug inserted in lcd acer x193w.) I show my "Acer" and turns off, then starts again and goes off...
Normally when you don't plug a monitor into your computer but just into the wall socket then you should get a No Signal message displayed. If the monitor is behaving erratically then it's not a good sign. Try plugging the monitor into your PC as well and see if it still keeps switching on and off.
Apr 17, 2011 | Acer X193W LCD Monitor
Monitor screen won't stay up. Monitor is connected to Gateway PC which is running Windows 2000.
http://www.retrevo.com/support/Acer-X193W-Monitors-manual/id/7197ag005/t/2/
You have to prove if it's the monitor or the PC, you must swap out, for Known Good, units. Check your monitor on another PC, try another Monitor on your PC. This will soon zero you in on the faulty item, be it, the monitor, or the Video card/PC
May 11, 2010 | Acer X193W LCD Monitor
Acer X193W not getting any signal when connected to 8600GT by DVI
If you know the cable and the place it was before
replace it and reboot the dude (Ps if you dont have the referce and instructions for the take a polaroid
Oct 19, 2009 | Acer X193W LCD Monitor
Just bought a acer x193w lcd monitor no sound
I assume the monitor has speakers built in . Have you plugged the sound card in to the monitor?
Jun 03, 2009 | Acer X193W LCD Monitor
My PC has no volume, I've tried everything I can but still no volume. Now wondering if it might be the monitor (x193W) but can't find where to adjust volume on monitor - Can you advsie please?
The full specs on the product note that there is no audio output. I just purchased the same model and am returning it because while it has power, VGA and DVI connections it does not have audio connections, which means no audio output on this unit.
Feb 02, 2009 | Acer X193W LCD Monitor
Crnt get no sound x193w lcd
As far as I know the Acer x193w monitor does not have speakers. In order for you to have sound you must attach speakers to the sound card at the rear of the computer. Usually indicated by a light green colored port.
Dec 20, 2008 | Acer X193W LCD Monitor
Drivers for the Acer LCD monitor X193W under Windows XP Pro.
The acer LCD monitor is plug and play.You don't need a driver.But unless you have a graphics card that supports at least 1440x900 you have problems. Also if your card has a div connection, use that instead of the analog connector, The monitor comes with that connector. Use the old one to connect a second CRT monitor if you want. Don't connect both to the lcd monitor and to the computer unless you are using a second monitor. Like everything these days, every purchase seems to need an upgrade of sorts, On board graphics **** anyway. Buy at least a 128 MB graphic card with a digital connector and more RAM never goes astray.....
Ron
Nov 09, 2008 | Acer X193W LCD Monitor
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Acer X193W LCD Monitor
Acer X193WBD Monitor Logo
161 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
