SOURCE: location of air ride pump
The airpump is located right above the exhaust. Its very easy to have it removed. I have had many problems with the air ride systems. Check to make sure the air lines werent rubbing against the tires...the compressor can be picked up used at many salvage yards for 50 bucks, but if te compressor is lifting the car, then there could be other issues.
SOURCE: my 2002 lesabre rear air shocks, pump works but
Trace the air line from the pump...usually on drivers side by air cleaner...under your car to the connection on each shock...
SOURCE: 1989 Buick Park Avenue, Rear shocks do not work,
You have a leak. Spray the air struts with soapy water to find leak while pump is running.
