Just register with Bose and you will receive regular updates for your system, so that it recognized the titles of the newer CD 's you may want to store
For pairing your bluetooth Bose speaker to your computer you might need to update the Bose speaker software
I have included the link to download the actual software, and the updates available. According to the page for the download, you will need to have the speaker connected to the computer with a micro USB cord.
SoundLink Wireless Mobile speaker update
I assume your display shows Bose 321 and refuses all commands?
Your problem is not very well described. Often when something like this happens you may be able to "reset" the system by removing the AC cord from the power and after a count of 10 putting it back in. Normally the display will start with showing the Bose 123 text on the display and will subsequently go dark. After that you can switch the unit on and it should work. If it does not, call Bose, sometimes just updating the software solves this type of problem. Ask for an update disk. Normally they send that free of charge to your registered home address.
It sounds to me like the Bose 123 is to blame not the speakers. I think you can test the speakers by connecting a 1.5 volt battery for a short while (few seconds) accross any of the speakers terminals. Disconected from the amp. If they are working it will go POP If it's the Bose itself then the main amp inside has failed.
yes use the Av cables for this connection . at the back of the TV there should be video in and Audio in connection.
for video its usually the yellow pin so yellow will go with yellow tv & m system
just follow colour code
ansd now u will get visual on the screen .
go here "http://www.dishnetwork.com/support/documents/receivers/default.aspx" to find your remote, then look at the literature to see if Bose is listed or for the code scanning for your remote. good luck!
Reset the system by unplugging the power cord and wait a minute before reconnecting power. The vocals will return. You should also contact Bose to see if your system needs a software update.
