Question about Home
Microwave stopped working-believe it has something to do with the door handle/switch. How do I go about repairing?
Whirlpool Mircowave Built-In Model MH7110XBQ-6 Microwave stopped working-believe it has something to do with the door handle/switch. How do I go about repairing?
  • 3,600 Answers
Go totthis web site and look up your model # they will have the break down proceedure for you/ http://www.appliancepartspros.com/
Posted on Oct 05, 2009
I have a kenmore over the counter microwave #721.80032 that is a 2010 model, and the microwave oven just stopped and doesn't work now, but the exhaust part does. Any ideas about what to look for or even...
The door switch is a common problem. Locate it at the front edge of the door. Handle side and try pressing it with a pen or something similar. Start momentarily to see if it works. Do not run for long because of leaking microwaves. That is a good place to start. Here is a link for more help. Kenmore Microwave 721 80032700Troubleshooting Repair Help
May 15, 2014 | Kenmore Microwave Ovens
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
Sep 04, 2013 | Whirlpool MH3184XP Microwave Oven
My mircowave door keeps cracking. This is my second door. Is there a recall on it? Model R 1612
Hi
I have an LG microwave its touch pad is not working .when the power is on it displays '0 and in no time it displays'co-l'.I'm not sure what does it mean .can it be repairable.plz help.
Dec 08, 2009 | Sharp R-1610 Microwave Oven
Handle-door
Look up your model number in the Whirlpool web site, they should have an online manual.
Jun 01, 2009 | Whirlpool MH1150XMQ Microwave Oven
Kenmore 1995 Built in Microwave humming sound only when door is close
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://www.searspartsdirect.com
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 22, 2008 | GE JE1640 Microwave Oven
Mircowave not heating
If when you try to microwave, the turntable does not heat, that's usually a bad door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Dec 24, 2007 | Samsung SMH7174BC Microwave Oven
Over the stove Mircowave just reinstalled...light is on but not heating up
If any wiring on the control panel was or might have been disturbed, I would want to check that. It may be that something (like a sensor) did not get plugged back in. Otherwise, I would verify that the door switches are working properly and the mounts for them are not loose or damaged. If this is a convection model, also check check the damper, damper motor, and damper switch. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded views, and often service manual portions here: http://www3.sears.com/
Jun 21, 2007 | Kenmore 80882 Microwave Oven
Home Logo
195 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
