Question about Toshiba Satellite A105 Notebook
Recovery console key convination for a laptop?
I want to boot my laptop to the recovery console, so that i can do a clean install of windows vista, do you know the key convination
my laptop is a toshiba satellite A105-s4064 with windows vista installed (i installed my self but it came with windows xp)
  • Toshiba Master
  • 4,806 Answers
Hi there.
Restart the PC and hit F2 while it boots up, this will take you into the bios, look for boot devices and set the CD to the first boot device, save the changes and exit the bios. The compuer will restart and boot from the CD drive.
Once the OS has installed go back into the bios and set the HDD (hard drive) to first boot device.
Good luck and thanks for using FixYa!!
Posted on May 11, 2009
Set msi 171f to factory defaults
Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash.
They will tell you how to do that.
Each Computer Manufacturer has their own way of making Recovery Disk/s.
Or borrow a proper Microsoft Vista DVD(not Dell, HP, etc).
A proper Vista DVD contains all Vista versions.
The Product Key determines which Vista version gets installed.
There are 2 Vista disks: one for 32bit Operating System, and one for 64bit Operating System.
If a clean install is required with a proper Vista DVD (not HP, Dell Recovery Disks):
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
http://support.microsoft.com/default.aspx/kb/918884
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
http://www.winsupersite.com/showcase/winvista_install_03.asp
Windows Vista Installation Super Guide
After installation > Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
Save all Data, as it will be lost during a clean install.
hope this helps
Jun 26, 2012 | MSI MS-171F (937-171F44-001) Barebone
Ntfs is missing
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
Forgot password, does not have cd rom drive, need to restore to factory settings. How???
How to obtain Vista Recovery Media and/or use the Vista Recovery Partition on your computer to put it back to Factory Settings.
There is no legal free Vista download available.
Contact your Computer Manufacturer and ask them to send you a set of Vista Recovery disk/s.
They normally do that for a small $ cost.
Also, ask them if you have a Recovery Partition on your Computer/Laptop to restore it to Factory settings.
See if a Manual came with the computer, or go to the Manufacturer's website, email or phone them for info on how to do a Recovery.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 09, 2011 | Compaq tc4400 Tablet PC (RL875AW#ABA)
My laptop is at a black screen that says windows boot manager......under that heading it says that windows failed to start due to a hardware or software change....how do i fix this?
does it offer you the option of pressing F1 to continue?
try that if you can, if its not there, it means the Windows Master Boot Record is broken and needs to be rebuilt.
Windows itself is likely to be ok.
If you have a Windows disk (if you are running Vista, the vista cd, and likewise with Xp, using the XP CD) - start the computer with the CD in the drive, and press any key to boot from CD when offered.
If it doesnt offer this, you need to change your boot order in the BIOS.
the BIOS is the screen right before the screen where you are getting that error.
it is the screen that counts up the RAM, around the Time the PC beeps jsut after turning it on.
there should be a prompt on that screen to get into Setup or BIOS by pressing a key. on Dell machines, it is F12, on IBM is often F2, and on my PC (an ASUS) it is DEL key you press to get into the BIOS.
once in there, you need to find the boot order sequence entry.
ensure the order has CD Rom before the primary hard disk.
save that and boot the PC, hopefully the CD will boot this time . when the CD starts up, you get an option to repair Windows, Install Windows, or enter the Recovery Console.
Press the key (i think it is ' R ') to Select Recovery Console.
once it loads up the DOS screen and is waiting for your input, just ype
FIXMBR
this does assume your Windows installation is sitting on your c:\ partition. refer to the following site if your windows install is NOT on c:\
Press Y to confirm and reboot the PC.
it should now load your copy of Windows.
Microsoft site has an article on the Recovery Console, so please refer to this for more information.
http://support.microsoft.com/kb/314058
Jun 24, 2010 | Computers & Internet
Laptop
You PC is going to need a windows rebuild
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access bios the and change the boot order. Also some PC let you select the boot device by hitting f12 when the system is booting up, if this is the case make sure your window cd is in then boot from your cd or dvd drive
  2. Once you have made this change in your bios you will see press any key to install from your xp cd
  3. press ender to start the Windows Setup. Do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you do not want to load Recovery Console).
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair.
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Mar 17, 2010 | Microsoft Computers & Internet
Back to get the original vista version
Well, with any amount of luck, when you installed xp you didn't erase the recovery partition. Just boot into the recovery partition. Some laptops will let you have that option on a regular boot.
Of course, if you have the vista cd, just boot with that. You can download a free vista recovery cd here:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
If that doesn't work, try to download easyBCD and hope that your vista partition shows up in xp:
http://neosmart.net/dl.php?id=1
Feb 02, 2009 | Acer Aspire 4720 Notebook
How to reformat R52 ibm thinkpad
Your laptop should have come with a recovery disk, you will need to boot to that disk following the onscreen steps for formatting and restoring the operating system files. Furthermore, if your system did not come with a recovery disk, or you have a Windows XP/Vista disk you can boot to that instead.
Windows XP Install:
After the installation system boots, the setup prompt will prompt you for searching the system for previously installed versions of Windows; bypass the recovery option after the search is complete. The setup will then display a list of Hard Drives to install Windows; follow the key for deleting the partition (press "D" to delete). Once the partition has been deleted highlight the "free hard drive space" and press "Enter" then you will be prompted to format the drive and install Windows. Moreover, you should right down the Windows Product Key off the sticker on the bottom of your laptop; you'll be asked for that key after the setup restarts your computer assuming you are using that license for that version of Windows.
Windows Vista Install:
When you boot to the Vista DVD you will be prompted to enter the product key as soon as the setup loads. Select the Hard Drive with the mouse, then left-click the format button on the right pane. Continue with the installation.
Nov 29, 2008 | IBM ThinkPad R52 Notebook
My laptop is not switching on
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" height="21" width="15" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
Oct 22, 2008 | Toshiba Computers & Internet
Toshiba Satellite A105 Notebook Logo
245 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
