That is an accurate description
the drum of all dryers is suspended from a combination of
felt pads at the drum ends
nylon glides under the drum
rubber tired thrust rollers.
the rubber tires wear, and the drum shifts, this pinches and wears the felts, then there is enough space to pinch the clothes in the gap
It is a simple enough fix, and well worthwhile, felts glides and rollers are cheap in comparison to new dryers.
Generically all dryers are pretty much the same, so when you go to the parts store, the felts rollers and glides may be labelled whirlpool or kenmore
they will fit exactly, there are very few that fit very many models.
To do the job
- UNPLUG DRYER
- If a top mounted lint screen, remove lint screen and 2 screws under lint screen from top of case
- with a putty knife or other blunt blade release spring clips at front corners of lid, retaining lid to front panel
- tilt lid up
- remove 1screw each side 1/3 way down front
- disconnect door switch wires
- remove front panel and door
- pull tensioner to end of its travel against tensioner spring, and unhook belt
(Note:: position of belt around tensinoer and motor pulleys for reinstall)
- pull drum out forwards
- motor, pulleys, support rollers, felts, and glides can now be inspected
good roller
bad roller
rollers are in pairs, if one is worn replace both
Inspect felts and nylon glides where fitted, any wear - replace
to replace felts
requirements 2 or more pairs locking pliers(visegrips) hitemp silicone adhesive
- pull old felt off
- scrape off old adhesive
- spread gllue on drum edge
- secure felt on drum with visegrip
- pull felt into place, clip with visegrip, pull again clip with visegrips, work around until felt is attached to drum and clipped in place
- allow glue to set
nylon glides, if fitted replace easily, a central screw, or glue
reassemble in reverse order
