Question about Canon MultiPASS F60 All-In-One InkJet Printer
Scanning When I scan a picture, it is not coming in clearly, it has lots of lines going through the picture. What is going on here? Anyway I can fix it?
  • 1 more comment
  • siehya Dec 13, 2007
    Thanks, I will give that a try!
  • siehya Jan 30, 2008
    Okay, just getting around to this, but where is the optic bar? There are lots of screws on this, just not sure where the correct ones are? I apologize, I am not that great at this stuff. Thanks!
    ok, all done, and still lines! how frusterating. any other ideas would be greatly appreciated! Thank you so much!
  • 121 Answers
Make sure your optic rial bar is well lubricated.Its easy to get to,two screws in the rear,and 6 clips,2 on each side and 2 in the front.Use lithium grease it is the best.
Posted on Oct 24, 2007
I DON'T KNOW HOW TO SCAN MORE THAN ONE PAGE
I know, I could go on the Internet, find your manual, read it, and learn if this machine has an Automatic Document Feeder. But I am not going to do that. It is a lot more than scanning three pages.
Anyway, IF the machine has an ADF, sort your pages, insert the stack with the TOP of the documents first. The recto of a page must be facing UP The ADF will sense that some action is coming. Press the Scan button on the machine. The connection to the computer must have been established before pressing SCAN. Also, the computer must have some software to open the scanned document.
You can also use the scanning software installed on your computer.
Nov 25, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Straight thin line prints on copies from feeder
When the paper is fed through Automatic Document Feeder (ADF) it is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying! For example see the below picture: -
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 18, 2011 | HP OfficeJet J4580 All-In-One InkJet...
Horizontal line
hi,
ur tv has problem with vertical scanning section. may be dry soldering or vertical output ic faulty.
u can easily find out the vertical section on ur tv. for that u have to open ur tv. u can see a coil is fitted on the picture tube neck. there are four lines coming from the neck, of which two will go to horizontal scanning section and the remaining two will go to vertical section. follow the two thin wire normally in color green and yellow. it will go to a socket in the main board. trace the track from that socket in the main board . it will lead u to the vertical scanning section. check for any dry soldering in that section. mainly the soldering of vertical ic. if see or not re-solder the leads of the vertical ic . then check is the tv is ok or not. if complaint remains replace the vertical scanning out pout ic. it will be fitted on a aluminum heat sink in the vertical section. if u need more assistance feel free to contact through fixya.
regards
Ajin
Apr 11, 2011 | JVC AV-20020 20" TV
Bkit yong tv ko my horizontal line sa screen nya ano ang dapat kung gawin dto
hi,
if u can understand English do the following
ur tv has problem with its vertical scanning side. vertical scanning output ic (integrated circuit ) may have some problem ( faulty or dry soldering in its leads). u can easily find out the vertical ic on ur tv. there will be four wire coming from the coil which is fitted on the picture tube neck, of which 2 will goto horizontal scanning section and the remaining two will go to vertical scanning section. just follow the two thin wire (normally in color green and yellow ). it will goto a socket on the main board. follow the track on the board. it will lead u to vertical scanning section. check for any dry soldering, if not , replace the ic.
ok
Jan 28, 2011 | Daewoo DTQ-13P2FC 13" TV
I have sony triniton tv when i was turn on there is horizontal line on the center of screen this problem was never happen before
HI,
ok
Jan 04, 2011 | Sony KV-35S42 35" TV
HP Scanjet 2400 scanning picture green and backgroud green
go to scanning software in ur computer change color section and remove this problem
regards
john
Nov 03, 2009 | HP ScanJet 2400 Flatbed Scanner
Color distortion with HP 2300 scanner
Hp scanner 2300c
while scanning a blue or red line appears on scanned imajes
Mar 17, 2009 | HP ScanJet 2300C Flatbed Scanner
Colorful lines down the scanned pages...
This could be due to excessive usage which the scanner can not tolerate and as a result the movement of the scanning mechanism losses precision. So avoid continous scanning.
Feb 08, 2008 | Microtek ScanMaker 5950 Flatbed Scanner
HP 710 Scan Problem
Cops is correct if you lift up ANY all in one machines, you will notice that there is a 1inch glass and then there is the main glass. When printing, scanning or faxing from the FEEDER it makes the copies from that 1inch glass,  if there is a DOT on that part of the glass it comes out as a line. Why? because the paper is moving that dot then becomes a streak on the paper. To test if it is a dot try doing it from the main glass, there should be no lines ( the paper is not moving!!!!).
sometimes it is very hard to see anything on the 1inch glass, but it's there, the background is black and it may be a black ink or pencil dot. To try and localize it, take the copy with the line and align it with the 1inch glass, look carefully and clean with alcool.
Sep 23, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Adobe interface issues
We have also seen that Adobe Acrobat doesn't produce very clear scans (with a range of scanners). Adobe gives very good pdf file size but it downsamples images.
Aug 08, 2007 | Ricoh IS 330DC Flatbed Scanner
Canon MultiPASS F60 All-In-One InkJet Printer Logo
20 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
