Question about KitchenAid Dishwashers
Kitchenaid 577-0 Rinse aid cap fell onto the heater element, became deformed. Need a new one. warranty? Without, dishes and glass is not clean,. John in Phx, Az
Buy a new one.  I had a similar problem.  Website link is below from where i purchased on for around $26+shipping.  I later found one for about $22.  Couldn't locate that website for you, but here you go:
www.apwagner.com/index.php?main_page=product_info&cPath=866&products_id=116675
Posted on May 28, 2009
THE RINSE AID CAP MELTED WHEN IT FELL ONTO THE HEATING COILS. I NEED A REPLACEMENT JUST NEED TO FIND THE PART NUMBER
If the model number you posted this question under is correct, the part number for a replacement Rinse Aid Cap is 8564929.
You can purchase replacement parts at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the model number is not correct, please post back with your correct information, or use your model number at the sites I provided, for your search criteria. I hope you find this informaiton helpful.
Feb 16, 2011 | KitchenAid 24 in. KUDI02CR Built-in...
Bad soap residue
Poor cleaning on this model is often due to debris in the sump area of the pump that blocks water flow to the spray arms. I have put together some instructions on how to clean this out. Follow the link and let me know if this helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
May 11, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Rinse aid not dispensing...ran out a few weeks ago, ever since that time lots of residue on started getting glasses and silverware. Put in rinse aid but don't see the level decreasing, can it be unplugged...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 20, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
White film left on dishes, does not seem to be cleaning thoroughly
could be several things... usually it just needs rinse aid.. all dishwashers spot or leave dishes cloudy without rinse aid.. or your water is just to hard, in that case you will need to soften it with salt, check the owners manual to see how that is done.. also run the dishwasher right after you put the dishes in, if you leave them for a day to wait to fill it up then the dried food gets like cement.
Dec 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Aug 04, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishes not getting clean
Since you are using a name brand detergent, open the filter area beneath the lower spray arm. Rinse out everything and remove any debris. While you are in there, look closely at the heating element- is it obviously broken or "bubbled"? Yes or no, the next most common problem is a failed heating element.
The heating element is imperative to activate the detergent and assure that the rinse aid works as advertised.
Good Luck!
Apr 08, 2009 | Kenmore Dishwashers
Spotty, filmy glasses
Even if you are sending it 120 degree water from your hot water heater, if the internal heating element has failed, your will get poor cleaning, including a film on your glassware.
Replacing the heating element will almost certainly fix the problem.
Good Luck!
Apr 03, 2009 | Maytag 24 in. MDB4000 Built-in Dishwasher
Our Whirlpool KUDP01ILBS2 dishwasher isn't working like it used to. Dishes seem to be getting partially clean, they aren't getting dry at all and it seems they may be being rinsed/washed with dirty...
Heat that is retained in the dishes is largely responsible for drying in this dishwasher. Since plastics do not retain heat very well, they will not dry as well as glasses, ceramics or metal dishes. Rinse aid must be used so that the final rinse water will sheen off of the dishes to accommodate this drying process. The heater element at the bottom of the tub is used to add heat during the drying cycle to aid in this process as well. This model of dishwasher does not have any forced air circulation system. Here are some tips that may help you resolve your drying problem:
  • Make sure that you are using rinse aid. Failure to properly use rinse aid can prevent proper drying. Adjust the amount that is dispensed if necessary. Also, check to make sure that rinse aid level decreases over time indicating that it is being dispensed properly.
  • The NORMAL WASH and POT & PANS cycles heat the final rinse water up to 140 degrees F. Use these cycles to help the drying process.
  • Do not choose the air dry option. This option cuts off the heater element during the drying process. NOTE: The heater element is not turned on during the first 6 minutes of the drying portion of the cycle.
  • Do not overload the dishwasher. Load the dishes to allow for proper water drainage.
This dishwasher has a heater fault detection circuit. If the heater is not working, the control will detect the lack of increase in water temperature. The dishwasher will stop and the CLEAN light will blink seven times repeatedly. The dishwasher would not be able to be used until the problem is corrected and the control is reset.
Feb 10, 2009 | Dishwashers
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Film on dishes
the problem is hard water. this is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
Oct 28, 2007 | KitchenAid 24 in. KUDU02FR Built-in...
Dishwashers Logo
617 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
