Monitor we hit a button and somehow our screen is now on it side and we need it to be upright thank you
  • 47 Answers
I don't what kind of monitor you have or how old it is, but there should be buttons on the front of your monitor.  Refer to owners manual on how to use them.  If you don't have the owners manual let me know, so I can try to find it for you. Good Luck!
Posted on Oct 14, 2007
I accidentally hit the auto-adjustment button on my monitor. Now, the an inch of of my screen from left to right is black. Not even my mouse can go into the black space.
Did you try hitting the Auto adjust again to possibly shut it off. Quite often the buttons work as off and on buttons such as the Caps Lock. you hit it and it's on. You hit it again. It's off. If you hit the Auto adjust it might shut off and re-adjust your screen to the original setting you had. ....don't forget that you made other adjustments to compensate for the mal adjustment that will need to be fixxed. good luck.
Dec 22, 2014 | HP W2072a 20in. LED-Backlit LCD Monitor,...
My i2352Fh monitor has developed a white vertical line which tracks back and forth across the middle half of the screen how do i get rid of it? the screen is 3 months oldn
Thanks Melony - had exactly the same problem - your post above helped me fix it...... Here is how to fix it .
  • On the base of the screen press the Menu button (far right),
  • Then press < or > to get to the Extra (looks like a screwdriver and spanner) and press Menu again to Enter.
  • Press < or > until you have selected the RESET and press menu again to Enter.
The line should be gone. Close the menus and all should be fine. I hope this helps someone. I searched the internet and this was the only post that gave me a clue. Thanks again.
Dec 16, 2012 | AOC I2353FH 23" WIDE Monitor
There is a large scratch on the screen, and appears black when the monitor is on. My monitor fell and hit the edge of a shelf because I had it leaning forward too much. Obviously, the mark is deep, and the...
It is evident that the LCD panel of the monitor is damaged. If your computer has Dell complete care you can get the monitor replaced. If not you can contact a local technician and get the LCP panel changed, with the remaining circuit boards and backlight assembly intact.
Jan 27, 2011 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
turn on your camera
press the menu button on the back og the camera
using the switch to the left of the screen, hit the left side once to move the screen cursor to the small icon on the left of the menu screen that looks like a "penci".
now click the button to move the highlight back to the right side then move up or down to select "07" Image Review.
hit the 4 way button on the right side to show the two options, on or off.
move the highlight up or down to select the one you want (assuming you want "on"), then press the center of the 4way button, "OK". now when you shoot a picture it will show up on the back screen until you touch the shutter release button again.
Dec 27, 2010 | Nikon D40x Digital Camera
Black color screen
Change your screen resolution to the highest setting first, in control panel, appearance/ themes. Next Push smart button on bottom right of monitor. Cinema mode should be highlighted hit autoset on monitor. Next hit the FUN button and highlight the 4:3 screen setting. This will expand your image to fit the screen without giving it that stretched and distorted appearance.
Jul 18, 2010 | LG W1953TPF 19" Monitor
My dell S1709W flat panel monitor turned white the Front Panel
NOTE: You can also lock or unlock the OSD by pushing and holding themenu-logo2.gifbutton for 15 seconds. (Top of the buttons on right side)
Apr 07, 2010 | Dell Computers & Internet
How to do adjust the height? I picked up the flat panel monitor today and it clicked clicked clicked down, and I see that there is some sort of button on the back, but somehow that does not seem to...
u can adjust the screen appearance by presssing the buttons on the front/side/ a hit and try as i am not sure which buttons do what function in ur monitor and how they are positioned...normaly it will have function/up/down/set etc..each option will increase, decrease, move up, move down, left, right, zoom out etc
Dec 24, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Setting tax
If the model is EL-2125 , and not 2125C or 2125E the following will work
1)switch on
2)press CE and then CA (you should see 0. with small 00 in top left hand corner but nothing else)
3)press M- button (rate set button),current tax rate 17.50% will appear with tax at left hand side
4) type new rate eg 15.00 (making sure to hit the decimal and two zeros, tax at the left and % should still be on the screen)
5) press M- (rate set button) (small 00 will appear in top left hand corner)
6) press = ( new rate and G will appear small 02 in top left hand corner and = sign below it)
hope this works for you, please let me know either way
Jul 31, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Black spots
If you hit the screen, then there is noting you can do. the lcd matrix would need to be replaced.
Apr 05, 2008 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
