Question about Nintendo Wii Console
After I turned on the power, The pointer was missing, so I can not select the program or function
    Novelist:
  • 149 Answers
There is a simple thing to find out if you need to by a new sensor bar. Becareful when doing this. Take 2 candles and set them apart, about the distance ofthe sensor bar. Your Wii remotes operate off of UV/infared. This is an alternate way to play the game with out having a sensor bar installed. Really cool the first time I did it. Any way if this brings you pointer back then you need to get a new sensor bar. They are only about 5-10 dollars at nintendo.com. If this does not fix the problem then that means that you need a new remote. You can also get that at nintendo.com you could also get them cheaper at game stop or something of that nature.
Posted on May 12, 2009
How do i get a driver for the onn mouse
go into control panel select device manager, go down to mice and other pointing devices right click mice select the device you want than right click of that device update drivers.
now if the drivers are missing than going to the manufacture website and go to support down load driver for nice or pointer device or it may be your whole keyboard mice are in the same programs and you would down load the file and install it.
thank you rod
Feb 28, 2015 | Computers & Internet
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
My mouse pad has a scroll function that isn't working.
make sure that the right type of mouse is selected it will be in the hardware tab also
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope this helps
Dec 17, 2010 | Computers & Internet
How do i change my cursor?
Go to Start and select Control Panel. In the Control Panel window click on Mouse. Now the Mouse Properties window should be open. Select the Pointers tab, now select the pointer you want to change. What I mean by that is that what your point looks like when nothing is going on, is different from the pointer that appears when a program is trying to load and so forth. Once you select the pointer you want to change, click on Browse... and a whole bunch of pointer options will come up that you can select and use.
Hope this helps!
Dec 16, 2010 | Computers & Internet
I am trying to set my Sanyo picture right side up. what setting do I go to?
Check Ceiling feature.
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT button(s) to move a red-frame pointer to
SETTING icon.
Language used in ON-SCREEN MENU is selectable from among
English, German, French, Italian, Spanish, Portuguese, Dutch,
Swedish, Russian, Chinese, Korean and Japanese.
Display
This function decides whether to display On-Screen Displays.
On ··· shows all On-Screen Displays.
Off ···· sets On-Screen Displays disappeared except;
? ON-SCREEN MENU
? "Power off?" message
? "No signal" message
? "Please wait...."
? P-Timer counter
Set a red frame pointer to item and press SELECT button.
Press POINT DOWN button to move a red-frame pointer to item
that you want to set and then press SELECT button. Se ting
dialog box appears.
Dec 11, 2010 | Sanyo PLC-XF46N LCD Projector
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
How do i program a 2004 malibu keyless remote
The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
The scan tool must stay connected until all of the transmitters are programmed.
  1. Install a scan tool.
  2. Turn ON the ignition with the engine OFF.
  3. With the scan tool, select Body,go to Remote Function Actuation.
  4. Select Special Functions.
  5. Select Program Key Fobs.
  6. Select the number of key fobs to be programmed.
  7. Press and hold the LOCK and the UNLOCK buttons simultaneously on the first transmitter for approximately 15 seconds . The Power Locks should cycle to confirm programming of the first fob is complete.
  8. If you are programming more than one transmitter, repeat the previous step to program up to four transmitters.
  9. Remove the scan tool.
  10. Exit the vehicle. Attempt to lock/unlock the doors to verify the programming.
  11. Operate the transmitter functions in order to verify correct system operation.
May 27, 2010 | 2004 Chevrolet Malibu Maxx
I have an acer laptop with multi-gesture tuoch pad that is driving me nuts. Can I make it function like a regular touch pad?
  • Hi, to Enable the Pointer Device; go to, Control Panel, click (Mouse) in the "Hardware and Sound" category. Go to; Device Settings, in the (Devices) block, click on, and Highlight; the item you want to (enable) this being the Pointer Device. Click the Enable button, just below. Be sure to (Click) on the Apply button, click OK. You may need to Update Drivers. Click on Hardware, select Properties, click, on Driver. If the, Update Driver (block) is not Grayed-out select to Update Driver2_bing.gif, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. "If this soluton helped, feedback is apprecited, paul7of9"
Feb 21, 2010 | Acer Computers & Internet
Left side of touchpad not working
Go to your "Device Manager" (Right click on ‘My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Pointer/Navigator"). If there is some kind of a "Warning" icon superimposed on the "Pointer/Navigator" icon there is your problem!
Uninstall the DRIVERS for THAT DEVICE only.
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.").
Or it could be dirt or soda.
Oct 29, 2007 | Compaq Presario V4000 Notebook
Nintendo Wii Console Logo
61 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
