Question about HP Photosmart 945 Digital Camera
Can u help??
I turn the camera on, the lens extends the screen flashes...
Then nothing....will not take picture will not flash will not display....
PLEASE> {:Please help....!!!!
~d~
  • 3 more comments
  • clwns Oct 25, 2007
    I bought new batteries and installed them...followed the reset insructions posted here.  The lens will not extend all the way out and still "no ones home".  Maybe the mechanism on the inside is messed up.
    Gears, something internal...any idea as to where I can go to get it checked out?
    Help in TN
  • bonniek Nov 11, 2007
    Yes, I have the same problem. I think my batteries may have died while the camera was on because it stopped with the lens still out. I tried other batteries and it still didn't work. I came home, recharged my batteries and tried again. It makes the noise like it is going to turn on, then it cuts back off. I tried taking out the batteries and memory card (for several hours actually) and it still doesn't work. Ideas? I love this camera and have had it for years. I don't mind to buy a new one if I can get one as good as this one, but I've had no luck with other cameras. The pictures seem blurry on them even though they are 6MP cameras and this one is only a 5.3 MP.
  • duckyboy Dec 06, 2007
    I have the same problem, only my problem started after the camera was dropped. I have reset it and tried everything, the camera acts like it is starting up, the lens tries to come out just a bit, then goes back in and the camera shuts down. HP has told me that they don't have any repair options for the camera. I love this camera also, I would buy it again in a minute. I am about to do surgery on it myself. Any info before I start would be greatly appreciated.
  • Anonymous Dec 07, 2007
    Lens is fully extended.
    Power on: red light flashes, them stops. No lens movement.
    Power off: red light flashes, then stops. No lens movement.
    Swapped batteries, no change.
    Am now re-charging a new set of batteries, will see what happens.
    Guess: it is toast. Out of warranty. Will probably look for another, cheaper, thinner, more reliable camera!
  • Anonymous Mar 17, 2014
    put in new batteries and turn on camera and taking pictures flashes on then it immediately goes to - lens error turn your camera off and on again. did so - it still flashes lens error message.
Change the bateries. Replace it with new acc.
Posted on Oct 22, 2007
2 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on May 09, 2010
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a...
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a message to power on and off again. I\'ve tried switching on and off a few times, removing battery pack and memory card, but nothing seems to be solving the problem.
Feb 19, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Flash pops up, but lens doensn't extend
there is nothing we can do at this time, you cannot repair this by yourself the miniature motor that drives the lens in and out could be damaged at this time nor the shuter mechanism that drives the assy, is binded mechanically
if this is still under warranty you might want to send this unit asap.
Aug 01, 2008 | Kodak EasyShare P850 Digital Camera
May 09, 2010 | Canon PowerShot A530 Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Won't turn on light flashes green then flashes red then nothing else
This usually means weak batteries, the other possibility is the lens mechanism is faulty or stuck. These cameras will shut down if the lens cannot extend or retract. Sometimes you can coax the lens out with a little help by pulling gently on the lens with your fingers if it starts to come out, don't force it. If you have dropped the camera with the lens out, this can damage the mechanism to either work intermittently or not at all.
Oct 12, 2008 | Kodak EasyShare C743 Digital Camera
Lumix TZ3 lens does not open
It is not clear if you are saying whole camera turns off or just screen turns off.
Notice before the camera went bad the lense does not extend in play mode, while it does in record mode. Many cameras have software that automatically turns camera off if lens cannot/fails to extend for some reason. Try to help it extend in record mode before camera turns off.
Feb 23, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Can't take pictures
The focus element within your lens may not be moving normally. This can be due to contamination such as sand, impact, or failure of the motor itself. If the lens cannot resolve proper focus the auto focus system on the chip will not continue to take the picture. Another possible reason is that the button has simply failed. David Millier Advance Camera Repair
Feb 07, 2007 | Canon PowerShot A40 Digital Camera
Lens won't open/flashes E18 on screen
i got my camera a couple of mounths, but i have not used it alot. When i turn it on, the start up screen wold come on but e18 would come up on the screen and nothing would happen after. i desperately need your help to fix my camera. thank you.
Sep 24, 2006 | Canon PowerShot A70 Digital Camera
Canon Power Shot Pro1 will not turn on
A new camera will fix problem perfectly. LOL Did you drop it? Seem like there might be a short or something similar. Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
Sep 09, 2006 | Canon PowerShot Pro1 Digital Camera
Won't Take Pictures
contact nikon they know about the problem and will fix it for free
Sep 02, 2006 | Nikon Coolpix 5700 Digital Camera
HP Photosmart 945 Digital Camera Logo
110 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
