Question about BenQ FP71G 17" LCD Monitor
Pc screen Pc monitor starts to flicker and shimmy also gose orange and green specialy when watching films. this happens after the monitor has been on for a while. The leads are all connected properly changing the frequency from 60 hertz to 75 hertz makes it slightly worse i have tried using a different monitor and the problem gose so it must be my current one which is a 19 inch edge10 monitor
  • BenQ Master
  • 2,404 Answers
Sounds like you maybe having problems with puffy caps on the either the power board or the main board. If you can open up the monitor its easy to see, normal caps have a flat silver surface where puffy ones the surface isn't flat and it looks puffy like its pregnant.
All you would have to do is replace the capacitors with ones of the same value.
Posted on May 31, 2009
My graphics is very bad...i cant watch films properly...when it starts up instead of a black screen it shows green...its all greenish now help
Hello
Check the laptop display on external monitor if it display green there its mean the display card gone bad and if it display correct colors then the LCD screen gone faulty needs replacement/repair.
Hope this helps
Jan 05, 2011 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Sep 27, 2009 | LG Studioworks 700S 17" CRT Monitor
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Orange light, no start
Well it could be the power supply, but, first try removing all the cards on the motherboard except the video card (remove and reseat that) assuming the video is no built in. Then turn it on. See what happens. Post back with results
Apr 04, 2009 | HP Pavilion 520w PC Desktop
Computer monitor stuck in safe mode
the problem is with ur Computer's Graphic card.
u can put a new one in case if it is a built in graphic card Chipset.
check ur manufacturer support page for more details.
plz rate this post as good as u can
Feb 06, 2009 | Dell Dimension 2400 PC Desktop
Screen does not start (switch on)
Sounds like a mode issue. Make sure you have the pc set to a compatible mode for the monitor. You may also want to double check the vga cable is firmly set in the monitor and pc.
Aug 22, 2008 | Hyundai ImageQuest Q17 17" LCD Monitor
Windows will not boot
Dear crab1,
check wether the RAM working properly or not because if RAM have some problem it might be possible that system get boot but u will not get the display. then check after booting is u r monitor power led gets red or green if it is green light then check u r monitor display property brightness, contrast etc. if u getting the red light it means the problem with u r RAM or Hard Disk.
Regards,
Bittu_8
Feb 13, 2008 | E-Machines etower 333cs PC Desktop
Pc screen goes black green light stays on
Well since you seem to have tried a bunch of thing why nor go a bit more and replace your video card. Below is a link to your PC:
http://support.packardbell.com/uk/item/index.php?pn=P280110001&g=1400
Dec 21, 2007 | Computers & Internet
BenQ FP71G 17" LCD Monitor Logo
127 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
