Question about Kenmore 20722
Kenmore 20722990 series won't spin or agitate
Makes a loudish sound when it's supposed to be spinning but doesn't :(
Fills with water just fine, pumps out water just fine.
Agitator barely moves.
Help! :(
  • blueextc3221
    blueextc3221 May 11, 2010
    drive coupling has failed.
  • 5,911 Answers
This is a direct drive washer that uses a motor coupling. It sounds like your coupling is broken. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupling can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If this is not correct, please post back with your make and model number.
Posted on May 11, 2009
My Kenmore 70 series washer sounds like it has something stuck in it and makes a grinding and buzzing noise the agitator will barely move but the washer will drain but not spin
That could be the motor coupler. It could also be the transmission. It is pretty easy to fix. I recently worked on my brother's washer:
Aug 04, 2012 | Kenmore 20722
Kenmore 80 series washer model # 110.92283100 that fills up with water then makes a horrible sound when agitating like the gears are stipped. Then it stops spinning and won't turn on for hours/
You might have a sock in the pump.
It might also be a broken coupler or a combo of the 2. The motor is overheating and shutting down on overload.. Could be a coin or something in that pump.
How it works service manual and repair videos
Let me know what ya find out
Jul 27, 2011 | Kenmore Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Kenmore 20722990 series 70 will not drain
I have the same problem right now. I found a dime in the discharge but it still does it. I am going at it from the front side of the pump now. I need disassembly instructions for the upper sections to get to it. It was really nasty dirty and stinks.
Mar 18, 2009 | Kenmore 20722
Agitator grinds and won't spin
You have a broken motor coupler, you can see how it is replaced on samurai appliance guru
Jan 17, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
Washing Machines Logo
408 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
