Question about Watches
When starting runs 5-10 seconds and cuts off.
Gas weed wacker: When starting runs 5-10 seconds and cuts off. Sears model 358.796140 - 28.0cc
Set up instructions to change the date and second hand
second hands are not set able they just run and run and run date now that is another story but we know not of the make /model or type of watch in question some use stem some use a mode button
Apr 13, 2015 | Watches
How to stop crying when you cut onion?
Hello.
You can just dunk the onions in Iced water for 30 seconds, or even boiling water, this will change the texture of the onion. Next thing to do is use a very sharp knife, start out by cutting the roof, it'll eventually release the gas. That's it.
Jul 22, 2014 | Odm Link SDD99B3 5 Watch for Women
I have a watch that I got from Sears Canada?. I need to know how to change the time. I got it in the summer of 2012. It had 4 buttons, mode (top left), indiglo (bottom left), set (bottom right), and s
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers
Nov 04, 2012 | Watches
We purchased a Casiotron R-11 watch, model number 54194. After many years the battery has gone flat, we replaced this but are not too sure how to set the time and date etc. Please can you...
Hey there, Setting the Time on the Casio R-11 until the R-15 ist quite simple: insert the Battery, the you should see the seconds counting on the top of display- depending on the model there are bars or squares blinking every 5 seconds and progressing until one minute is done, then it starts again. When all the bars for the seconds are filled, simply press the button located on the left side of the watch. You can press it by using a pen etc. Now the Hours start running, let proceed until the right time is displayed (notice the a.m. or p.pm. bar on the top/right of the display). When you reached for example 10 (for 10:00 in the morning or night), then you push the select button on the right,then same procedure with the minutes. When you finished selecting the hours and minutes press the button on the right again and the watch starts with the time with 0 sec. You cab set the date by pushing the select button on the right and simultaniously pushing the button on the left with a pen.
Hope it works out
May 05, 2011 | Casio Watches
Why isn't the second hand on my Wenger Commando SR not working? The red seconds hand is not moving. The small seconds counter of the chronograph works and the minute and hour hands work.
The large seconds hand will remain at 12 unless you press the upper right button to start it. Pres again to stop it and press the lower button to reset it. The small seconds hand that always runs is the seconds for the time. The large seconds hand is for the stopwatch function. If you like to have it running all the time just start it and leave it running - it won't harm the watch.
Jun 02, 2010 | Swiss Army Wenger Commando 70725 Wrist...
Seconds ticker jumps,stops,jumps
It means that the reserve power is getting low and the energy cell needs to be fully recharged by exposing it to light for a period of time outlined in your owner's manual. This may also occur after fully recharging your watch after a complete discharge of the energy cell. If you have fully charged your watch and the second hand continues to move in two second intervals, you need to do an all reset of the watch. For simple analog models, pull the crown out to the time setting position for 30 seconds, then return the crown to the closed position next to the case, then set the time. For multi-function models, please refer to your owners manual.
Jun 15, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen Eco Drive second hand stoped working
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, or watch does not run okay? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life. As long as the watch keeps running I believe it should keep good time. It is quartz anyway. If this is not the case, and a good sunbath does not help, the mechanism could be running heavy, possibly due to overheating the watch; no help there...
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
May 31, 2009 | Citizen Eco-Drive BL5184-56L Wrist Watch
Can't get new eco drive watch to start!
Okay, if you say your battery goes bad, or the watch does not run? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
Dec 06, 2008 | Citizen Eco-Drive Silhouette EW869452D...
Rolex ad Daytona 1992 replica
The advice given here is accurate to a degree. When wound, a rolex daytona IS running. However, it is the running seconds hand in the small sub-dial that is actually running. In the earlier Daytonas, this sub-dial was at the 9 o'clock position on the dial, (pre-2001 series daytonas). The later daytonas, from 2001 on, use the seconds at 6 position for counting seconds. The main sweeping second hand on the watch dial will NOT start until activated by the pusher at the 2 position. That pusher needs to be unscrewed and then pushed to start the large sweeping second hand. This action, in turn, starts the remaining 2 sub-dials in motion, counting minutes and hours. To stop the chronograph function, you push the pusher @ the 2 position again, to stop the sub-dial hands from counting, and then push the pusher @ the 4 position to re-set the dials to their "straight up position". This stops the chrono's function, until it is needed again, BUT the main running seconds, (at either the 9 or 6 sub-dial position, depending on the year series of the daytona) will continue to run, thus keeping accurate time.  Hope this gives you a better idea of how the timekeeping of the chronograph function on a Daytona works. So, to start your seconds running you need to start the chrono function by pressing the pusher at the 2 position. That will allow you to see the large sweeping second hand I think you're referring to here. Hope this has helped.
Doug
Jan 11, 2008 | Rolex Daytona 116520 Wrist Watch
Ebel sportwave chrongraph
It;s probably a difective movement mechinism.
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Ebel 1087902 wristwatch
Watches Logo
60 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
