Question about RCA 32V550T 32" TV
Rca 32v434t no sound no picture hv ok
  • 7 more comments
  • jr1999 Nov 22, 2007
    WAS WATCHING A PROGRAM HEARD A CLICK AND NO PICTURE OR SOUND. UNPLUGGED FOR 15 MIN. AND PLUGGED BACK IN. HEARD PRIMARY POWER UP AND A BEEP. PUSHED POWER BUTTON AND RED LIGHT BLINKED ON AND OFF CONTINUALLY. NO PICTURE OR SOUND. CHASSIS NUMBER IS ATC010A.
  • kylesbaby Nov 30, 2007
    Exact same problem. TV shut off while we were sleeping. When you plug in, it clicks like it's coming on, then really high-pitched, short beep, click, "red-blinking-light-of-death" on the front of TV, then NOTHING
  • Anonymous Feb 11, 2008
    My new 32V434T tv worked for four months. Then, the picture and sound went out.
  • Anonymous Feb 26, 2008
    We have the same problem with our RCA 32v434t. No sound, no picture, just the red light that blinks. Quit working on the one year anniversary of purchase so getting warranty work fortunately.
  • Anonymous Apr 05, 2008
    no sond no pic red light blanks 25 times
  • Daniel D Dupont Apr 08, 2008
    Replaced the flyback transformer and the horizontal transister. The TV powered up then shut back off.The red light on front stayed on.I tryed to turn it off and on but it did nothing. I unpluged The tv for a few minutes pluged it back in and it turned on and right back off again.RCA 32V434T
  • Anonymous Apr 14, 2008
    no sound or picture,remote will turn the tv on but will not turn it off.
  • ltwil Jul 07, 2008
    my tv clicks off when i turn it on and theres no sound or picture i have had same problem twice before
  • mpeprobert Nov 16, 2008
    2 years old bought from walmark rca 32v434tyx5 no sound and no picture just the red light on. can you help?
    robert
Isn't there someone out there that knows something about tv's
there has to be an answer to this problem.
Don;t try to tell someone how much it costs or they should junk it tell them whats wrong.
Posted on Apr 13, 2009
Try messing with menu button if i hold it in while powering up tv it will stay on if i release it it goes off
Posted on Apr 22, 2008
Bought same television 32v434t from walmart went out after seven months rca sucks,having tv fixed but not under warranty if you people want to know what the prob is its a transformer and it also burns out some of the cicuit board on the horizontal having tv fixed the cost for me was $210
Posted on Apr 07, 2008
Went in the menu and blocked the panel buttons on accident
Posted on Dec 03, 2007
Turned on tv no picture only sound then i heard a pop and smelled burning tv turned itself off. 5 min tried turning on tv again nothing happened tv does not turn on at this time
Your RCA TV needs serious troubleshooting. Burning smell is from HV transformer or resistors smoking.
Most likely power supply and/or high voltage circuit or convergence circuit. Many times RCA have multiple or secondary faults that occur with HV or convergence failure.
Repair of RCA HV or convergence usually requires exact manufacturer parts and upgrades or repair in power supply. I would not advise trying this repair without manufacturer support for correct part numbers and service bulletins.
easyab
Feb 28, 2010 | RCA Televison & Video
RCA 32V434T Changed recomended part: New Problem
Was the xformer RCA, new in the box ?.........
The silicon rubber seal is to moisture entry. Do not re-apply.
Make sure your connection is good.......
Did you hook-up signal to verify no sound ?
NSNP , HV ok = something wrong other than xformer....
Check all power supply voltages.....................T.
Check top of electrolytic caps for expanded,bulged or
what techs call "pooched".....................
Apr 17, 2008 | Televison & Video
Tv no pic or sound
If you hear the high voltage try to come up and set shuts down in 2 secs it could be your FBT also these sets have alot of poor connections chassis should be resolder.
Apr 06, 2008 | Televison & Video
RCA 32" 1996 COLOR TRAC PLUS
Hello neall,
It sounds like you may have a power supply problem- (HV Power supply). I must ask if you have sound or not? If you have sound it is the HV supply only if you do not have sound the Low Volt power supply and possibly the HV power supply/Horizontal section has a problem. I would suggest that you take the TV to a qualified TV repair shop.
I hope this helps,
Thank You,
Shuttle83
Mar 18, 2008 | RCA F32632SB 32" TV
Rca 32v434T need part numbers
The H.O.T. Transistor number (original is 2SD3402 (which is no longer available)) it's replacement is the 2SC5902.
The H.O.T. Transformer part Number is RCA 271996
Oct 30, 2007 | RCA 32V550T 32" TV
Power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Sep 26, 2007 | RCA 32F531T 32" TV
32v434t dead
please go according to procedure 1 isolate h/output section supply. 2 check power supply output is ok if not repaire it. 3 after power supply is ok 4 check hor osc, driver &output if problem repair it. 5 check for loose contact or print break. 6 connect supply to hor section. set will work fine. good luck.
Sep 21, 2007 | RCA 32V550T 32" TV
RCA 32V550T 32" TV Logo
354 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
