Question about Sharp 27G-S60 TV
Sharp 27G-S60 no vertical picture
The problem has been intermittent for a while, but now is permanent.  After turning on the TV only displays a horizontal bright line and you can see the picture "moving" behind the horizontal line.  The sound is fine.  I remember on old tube TV's there would be one or two tubes responsible for vertical control, pop the old one out, pop a new one in - done!  Any home-based tinkering solution here?
  • Justfixxing Dec 23, 2008
    My sharp tv is old and has the same intermittent problem. It usually goes away but has been more frequent lately. Horizontal line only on screen, with color going across; sound is fine.
    An expert who has answered 500 questions.
  • 556 Answers
Your problem is due to vertical section failure.
 as you say it was intermittent for a while, but now is permanent
please check the followings as given
  • remember you should keep brightness as low as possible to avoid crt burn.
  • there might be loose contact in print or connector loose for deflection coil.
  • check supply to vertical output section
  • check components in vertical output section like electrolytic capacitors & low value resistirs.
  • check verical outout ic .
  • hope this will help
  • good luck.
Posted on Oct 15, 2007
Looking for parts for my TV - if you thinking of selling let me know
Posted on Aug 18, 2008
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Hi I have a sharp 27H S60, has worked fine for many years. Now, I get fine sound but no picture. When it is first turned on I get a thick white line in the center of the screen for a second, then it is...
The problem is a vertical deflection issue, it means the picture from top to bottom has collapsed. The set will require two or three capacitors and an ic and it is quite fixable.
Feb 07, 2011 | Sharp 27H-S60 TV
Only a horizontal line can I see in my TV
In most cases the vertical output IC and possibly a fusible resistor off of the high voltage transformer are bad. The vertical output IC is located on a heat sink and usually right next to the vertical yoke winding connectors that are green and yellow in most sets. Please take a moment to rate my answer..Thanks...
Nov 24, 2009 | Sharp 27G-S60 TV
Top of picture is distorted
the problem of your tv was in the vertical section.if you can locate the vertical section, change the capacitor value 100/50volts
May 09, 2009 | Televison & Video
Turns on but quickly turns off
you have defective power oscillations! in this model you have to replace the vertical output ic. because the power oscillation for Jungle IC is passing by from Vertical output.
Dec 29, 2008 | Sharp 32U-S60 32" TV
Sharp - 27G-S100 Pictures starts to pulse / flutter. When we smack(slightly) the side or the top, the picture then becomes normal. Now the unit won't even turn on.
sounds like you have bad solder connections usuall on whats called the vertical amp IC. This prob;em is very fixable but you would need solder equipment and experience to do it yourself or it would need to go to the shop.
Mar 10, 2008 | Televison & Video
Vertical reduzida
Solder pins of vertical output circuit, solder any and all bad connections.Other experts = please translate in Spanish.....T.
Nov 19, 2007 | Sharp 27H-S60 TV
Sharp 27G-S60 TV analog or digital?
Call 1-800-237-4277 1-800-BE SHARP
FAX 1-630-378-9981.................................................
Oct 21, 2007 | Sharp 27H-S60 TV
Sharp 27G-S60
it is cery simple as it folds after an hoyr or so. as you are asking for the section where the problem is located so is in horizontal oscilattor section.(possible cause cap.might be defective.) as per ckt diagram is concerned is concern please seeweb site hope this will help
Sep 30, 2007 | Sharp 27C-240 27" TV
Televison & Video Logo
142 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
