Question about Cam Spray 25006PM 2500 Psi Cold Water Gas Pick Up Mount Pressure Washer With 300 Gallon Water Tank
Trying to find how i can build my own trailer mounted sprayer for dust control
    President:
  • Cam Spray Master
  • 1,383 Answers
No need to re-invent the wheel when building your trailer mounted sprayer. Your local Northern tool Store, or at the address below,
http://www.northerntool.com/webapp/wcs/stores/servlet/category_6970_166839
you will find all the parts that you will need to complete your project. I have purchased several different types of sprayers, tanks, pressure pumps and parts from them over the years. They have a helpfull staff and most parts are in stock. Take a look at ready made trailer mounted sprayers there to pattern yours after then design in your special needs.
My first portable sprayer was made from four 55 gallon drums loaded onto the back of my pickup. For the pump I used a modified 2" trash/water pump reduced to 1' pipe then seven nozzles. Worked great however 220 gallons of water did not last very long. Problems began with the weight of water in large quantity. I decided I needed about 1000 gallons and found that I needed to deal with about 7500 lbs of weight. Oh well, enough already, good luck with your project and email if you have questions.
Posted on May 12, 2009
Sprayer looses pressure pump issue ?
You can take the intake part of the pump apart and clean/lube the diaphragm of the pump. If you didn't clean it out last time it was used there will be residual or cake built up. Make sure the down snorkel is clear and doesn't have any contamination in the tube. Check the screen/filter also.
Jul 03, 2014 | Fimco 25 Gallon Trailer Sprayer with a 12...
Parts sprayer stanley
I would like the answer yo that question
May 10, 2013 | Stanley Professional Backpack Poly...
My sprayer is new, but does not keep the pressure, any idea's? It's a 2 gal, pump up type sprayer.
Check under the lid/cover for a rubber gasket. This may have gotten unseated when putting the sprayer top on. It must form a tight seal around the lip of the sprayer top in order to keep the pressure. Alternative: Put water in the sprayer leaving some air on top to build pressure. Put a few drops of dish soap inside and gently stir. Put the cover on, and tilt the sprayer to coat all areas at the top. Start pumping and see where the bubbles come out---there is your leak. If it is near where the sprayer hose enters, and it is a permanent mount, you may have a bad seal. If the sprayer hose unscrews, you may need a new rubber washer inside. If bubbles come out of the wand, or other plastic seams, you may have a crack in the plastic. Depending on the location, you could epoxy over the crack to seal it permanently. Good luck.
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
I have a 15 gallon Fimco trailer sprayer. Last
Bleach gives off corrosive vapors, so the internal parts of the pump may have corroded over time. Least expensive fix is to disassemble the pump, find and replace any corroded parts, but you'll be tinkering for a day and it may not be repairable anyway. More expensive but faster is to replace the pump - check the GPM rating and find it here for about $60 - $100. Good luck!
Jul 05, 2010 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Does anybody know how to wire a towbar wiring unit to a ford escort 1999?
Wiring the vehicle for towing is fairly easy. There are a number of good wiring kits available and these should be used, rather than trying to design your own.
All trailers will need brake lights and turn signals as well as tail lights and side marker lights. Most areas require extra marker lights for overwide trailers. Also, most areas have recently required back-up lights for trailers, and most trailer manufacturers have been building trailers with back-up lights for several years.
Additionally, some Class I, most Class II and just about all Class III and IV trailers will have electric brakes. Add to this number an accessories wire, to operate trailer internal equipment or to charge the trailer's battery, and you can have as many as seven wires in the harness.
Determine the equipment on your trailer and buy the wiring kit necessary. The kit will contain all the wires needed, plus a plug adapter set which includes the female plug, mounted on the bumper or hitch, and the male plug, wired into, or plugged into the trailer harness.
When installing the kit, follow the manufacturer's instructions. The color coding of the wires is usually standard throughout the industry. One point to note: some domestic vehicles, and most imported vehicles, have separate turn signals. On most domestic vehicles, the brake lights and rear turn signals operate with the same bulb. For those vehicles without separate turn signals, you can purchase an isolation unit so that the brake lights won't blink whenever the turn signals are operated.
One, final point, the best kits are those with a spring loaded cover on the vehicle mounted socket. This cover prevents dirt and moisture from corroding the terminals. Never let the vehicle socket hang loosely; always mount it securely to the bumper or hitch.
You can check HERE details about this part for Escort and any "graphics".
Hope help.
May 21, 2010 | 1999 Ford Escort
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco 15 gal Sprayer, 12 volt, No power
cross the wires on the pressure switch, if it runs then, replace that switch is all!
Jul 02, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco Sprayer , 25 gallon, 2.1 gpm, 12 Volts - Blowing fuses
Soiunds like you either have one of two things. Either the pump motor is bad or you have a wire that is shorted out. look for chaffed or bare wires or burnt spots on the sprayer and the machine towing it. one of the two is your issue. Hope this helps!
Sep 19, 2008 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Cam Spray 25006PM 2500 Psi Cold Water Gas Pick Up Mount Pressure Washer With 300 Gallon Water Tank Logo
154 people viewed this question
Top Cam Spray Garden Experts
John Trevino
russlakeside
Level 1 Expert
Are you a Cam Spray Garden Expert? Answer questions, earn points and help others
