My machine will start and run for about 20 min to 30 min then it stops during the cycle and all i get is blinking lights (3 at the same time) and it will not continue. Any idea? Thank you
-   My dishwasher does not clean. The water does not spray yet everything else works fine. Any advice is greatly appreciated!
-   wolffbark
Jan 02, 2009
-   I have the same problem with my Kenmore model 665 (Stock No. 16769). Various lights will blink, changing from time to time, and I can't make them stop or otherwise start the machine.
-   ghfalter
Nov 28, 2008
-   Washer stopped both the wash cycle light and the wash button lights are flashing, water in bottom.-   les_14647
Nov 10, 2008
-   I have a similar problem. It appears to almost complete the wash cycle and it stops. Lights are flashing and then I press cancel to drain and have to keep pressing the cancel button because the water doesn't want to drain. HELP!!!!-   Guest
The washer will turn off during the cycle. If I open and close it, it will come on and resume. But...
(More)
The washer will turn off during the cycle. If I open and close it, it will come on and resume. But it seems to be at the 42 minutes left mark during "water heat." I have recently had to cancel, drain and put through the quick wash.
I have SMEG DWI710 given with the house. The power light is on but it does not work. The start...
(More)
I have SMEG DWI710 given with the house. The power light is on but it does not work. The start button is always in the up position is that right or is it suppose to click down. The power on off button is the only one that does anything altho the others with the exception of start do click down. I have a copy of the almost useless manual it says nothing. Help !!
