Question about Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D CF memory card won't go into slot
Canon EOS 350D CF memory card won't go back into slot, so I can't download my images or use it to take more. Any ideas? It's just suddenly stopped working.
  • 37 Answers
It sounds like you have some bent pins in the card slot. Take it to a reputable camera repair and they can look and tell you for sure.
Posted on May 12, 2009
Broken cf slot in canon 350d camera
CF pin assembly is soldered onto the main circuit board. Replacing this requires a soldering work station with a good heat gun
Mar 24, 2014 | Canon Rebel XT / EOS 350D Digital Camera
After I removed Cf card I inadvertently pressed
Have you tried inserting the card while pressing the remove button at the same time?
Feb 12, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canan 350D with CF error, says no image on screen. How do I fix this?
The memory card could be bad, try formatting the memory card, or the camera could be damaged. Look inside the memory card door, take out the memory card and look at the little pins in the camera that the memory card connects to. If any are bent or missing then the camera will need a major repair to be fixed. This is something for Canon or qualified technician to fix.
Nov 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
When i start camera power on it flashes Err CF will not allow me to take pictures
Assuming you have inserted a CF memory card; try a different one. This is typical of a defective memory card. Also, look into the slot to verify no bent pins(they are tiny!)
I do not know if this is applicable on the XT, but some Canon's have a setting to block/allow taking pictures without a memory card inserted. If it does, set it to allow to verify the camera is operable otherwise.
Sep 24, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I removed my CF card to download the images and now cannot reinstall it. I tried a second card and it will not install either.
I found one pin bent inside the cavity for the CF card. I carefully used a small jewelers screwdriver to straighten it and then reinserted the card. It worked, which surprised me.
May 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Lost previous pics after checking used memory on CF card
have you used the card since if not there is a program you can download that can help recover the datahttp://www.pcinspector.de/Sites/smart_recovery/info.htm?language=1
Feb 23, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon camera has error cf
Of course you have tried to format the CF card ? That can solve the problem.
If you get err 99 when trying to format the memory card, the problem is probably in CF (Compact Flash) connector. One common reason is bent pin. You can see it when looking into card slot.
Another possibility could be the CF connector terminations inside the camera. I repaired one EOS 350D where solder joint in one of the pins (23rd) was broken. And that looked like manufacturing failure in the printed circuit board (see the picture). The solder pad for that pin was far too small. There can be also other such cases in the market. The disassembly of the camera is rather difficult but if you have some experience on that kind of work, it is worth trying when you have no other option. Some guidance for disassembly can be found for example here: http://astro.ai-software.com/articles/mod_350D/mod_350D.html
Aug 03, 2008 | Canon Digital Rebel XT / EOS 350D Body...
CF Card is not being read, Canon Digital 350D EOS Problem
It does not sound good. You might want to get a flashlight or similar and look into the memory card slot to check the connector pins in the camera. They may be bent or damaged.
Jul 27, 2008 | Canon Digital Rebel XT / EOS 350D Body...
Scandisk curropt
You'll need a CF reader/adaptor for your computer, and software such as this
http://www.softwarepatch.com/software/smartrecovery.html
Just type "recover CF card data" and you'll find a host of downloads.
Oct 18, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
1,060 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
