Question about Dryers
No heat coming from the dryer
Kenmore 80 series gas dryer-tries to ignite, it glows, but will not light
  • 460 Answers
I hope this information will help U
http://repair2000.com/norun.html
check inside the dryer
http://www.youtube.com/watch?v=rQV-z4f7fvA
with this video I send you is not for you to buy anything is just for you to check your dryer.
When you find was it the problem let me know and I help you to instal it.
was this helpful
Posted on May 14, 2009
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
Kenmore 80 series dryer, no heat. blower works
Check to see if the glow bar is coming on first. If it isn't, it is probably the thermal fuse/ cutoff. It is a small white plastic piece on near the motor housing.
http://www.partselect.com/PartDetail.aspx?Inventory=345113&SourceCode=6
or
http://www.partselect.com/PartDetail.aspx?Inventory=344958&SourceCode=6
If it is coming on but not lighting the flame, then you probably need gas coils. They are the two cylinder shape black and white objects attached to the gas valve.
http://www.a-1catalog.com/gasvacokit2.html
Jan 15, 2010 | Kenmore 73952 Gas Dryer
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
Dryer will not heat up
if the ignitor doesn't glow it could be broke it is vary fragile, and made of carbon, you might want to have a tech come out, if you can see it with a flash light it has 1 screw that holds it in place if you can get it out unplug it, take it to R.E.Michaels a supply house over the us if not look for an appliance co, that has parts and you have to get the one with the same plug and hold down. you can instal it your self but remember do not touch the carbon part, it is sensitive to the oils in your skin only handle with the hold down,, if you touch the caron as soon as it lights up it will break, no doubts in that----good luck
May 30, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer does not heat
I have a kenmore series 80. Had the same problem...the fix was replacing the gas coils. The dryer would get hot for about 10-15min then nothing. The gas would stop firing but you could see the igniter glow over and over again. Hope this helps.
Apr 02, 2009 | Kenmore Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
141 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
