Question about NetGear WGR614 Router
Win xp network
I cannot connect my laptop with the router (netgear wgr614) wireless i setup the router on the same laptop and it worked with the Ethernet (cabal) , but when i scan for wireless network (while the cabal still plugged in) the windows cannot find a wireless network so pleas help !!!!!!
  • 1 more comment
  • aboodibrahie May 11, 2009
    i did that , dont worry am not that stupid
    the key is on
    OK thanx i will try it then i will post you.................
  • 854 Answers
Check the wireless switch of your laptop if "on" or not. Then try again to scan available wireless network
Posted on May 11, 2009
  • redhaze89
    redhaze89 May 11, 2009
    ok good..
    Here's a thorough set up
    Here are some troubleshooting steps that I suggest you try:
    1. Check physical connections.
    a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
    b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
    2. Access the router's web-based utility.
    a. Please open any web browser like Internet Explorer or Netscape Navigator.
    b. Connect to the router by typinghttp://routerlogin.com/basicsetting.htm orhttp://192.168.1.1 in the address field and click Enter or Return key.
    c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
    Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
    To reset the router:
    a. Please push the reset button at the back of the router and release after 30 seconds.
    b. Unplug the power adapter for 10 seconds and then plug it back in.
    3. Configure the router.
    If your Internet Service Provider is using a cable connection, please follow the steps below:
    a. Click on Basic Settings under Setup tab.
    b. Select No for Does Your Internet Connection Require A Login?.
    c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
    If your Internet Service Provider is using a DSL connection, please follow the steps below:
    a. Click on Basic Settings.
    b. Select Yes for Does Your Internet Connection Require A Login?.
    c. Select Other on the Internet Service Provider drop down box.
    d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
    4. Configure the wireless settings.
    a. Click on the Wireless Settings under Setup.
    b. Change the SSID to any unique name.
    c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
    d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
    e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
    Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
    f. Click Apply button to save the changes.
    g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
    5. Power cycle.
    a. Power off the modem, router and computers.
    b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
    c. Power back the router and the computers. Check if it will be able to get online.
    If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
    6. Connect wireless computer to the router.
    If you are using Windows XP with Service Pack 1, please follow the steps below:
    a. Please right click on the Wireless icon on the right lower end portion of your computer.
    b. Then click on View Available Wireless Networks.
    c. Click on the Advanced tab.
    d. Please delete all the preferred networks then click on OK.
    e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
    f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
    g. Make sure not to enable IEEE and then click on Connect.
    If you are using Windows XP with Service Pack 2, please follow the steps below:
    c. Click on the Change Advanced Settings.
    d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
    e. Right click on the Wireless icon then click on View Available Wireless Networks.
    f. Select your network and click on Connect.
    g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
    If you are using Windows Vista, please follow the steps below:
    a. Click Start then select Connect To.
    b. Connect to a network window will show up.
    c. Select your wireless network and click Connect.
    d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
    From the above configuration, please check if you can now access the Internet.
    No Wireless Connection Found in Range
    Note: You need to use a computer hardwired to the router to check the wireless settings.
    1. Please open any web browser like Internet Explorer or Netscape Navigator.
    2. Connect to the router by typinghttp://routerlogin.com/basicsetting.htm orhttp://192.168.1.1 in the address field and click Enter or Return key.
    3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
    Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
    4. Click the Wireless Settings under Advanced tab.
    5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
    6. Click the Wireless Settings under Setup.
    7. Change Channel (recommended are 1, 6 and 11).
    8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
    Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
    Other factors that you may consider when you are not able to view any available wireless network:
    a. Switch for the wireless adapter is turned off
    b. Distance between the wireless router and computer
    c. Possible wireless interferences
Just purchased a WGR614 wireless router for my dell laptop. the instruction manual only mentions connecting to external modem, what if you have a laptop with an internal modem, how do you connect? My...
Thank you for using FixYa
Wireless connections have a lot in common so here is a link that will give you the general configurations for a wireless Router to PC. Keep in mind that you will need to configure both the computer and the router in two separate steps. That is why it is best to use the setup disk that normally comes with a new piece of equipment and the cables.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Also keep in mind that the equipment should be matched or designed to work with the other equipment. You will have some kind of a modem either a cable modem or internal modem or external modem that the router will have to connect to.
It is best to allow your own Internet Service Provider to set up the connections. They may not be able to support the configuration if you do not purchase it from them and then you will need to do-it-yourself.
Here are the links for configuring the computer with the different operating systems
Win XP http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Win Vista
http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Win7
http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this was useful and please comment if this was helpful to you.
Mar 23, 2011 | NetGear WGR614 Wireless Router
Laptop can not connect to netgear wireless router
I would suggest using the network setup wizard, in the control panel. Best option is to copy the data to a pen drive and transfer to your daughters laptop.
May 30, 2010 | NetGear WGR614 Wireless Router
Trying to connect netgear wgr614v9 router to new toshiba computer with windows 7 ....setup says unsupported operating system....what do I do
As netgear setup disc doesnot support Win 7.
U need to manually setup the netgear product
-- hard resett the router using a restore factory setting hole on the back of the router
-- open the netgear router page using www.routerlogin.com
-- Username - admin , Password - password
-- run setup wizard
-- if it detects dynamic ip then press next
-- and on the left u will see wireless settings under setup .
-- secure the network using WPA_PSK(TKIP)
-- and then apply .
In case if it will detect static or fixed ip .
Then click on " Basic settings "
-- Under router MAC address
-- select "use computers MAC adress "
-- Apply
-- And then Powercycle the network..
-- And u will be able to go online ..
Jan 02, 2010 | NetGear WGR614 Wireless Router
My printers that are on my wireless network won't print
Did you define the printers and printer ports to the laptops?
On the XP laptop go to network connections in the control panel and use the network setup wizard.
Jan 01, 2010 | NetGear WGR614 Wireless Router
Xbox360/netgear WGR614 V9 connection issue
Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
Sep 19, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
My HP laptop won't connect to my NETGEAR WGR614v7 router
What is your operating system (Vista/XP, older Windows)? Have you turned on the router's wireless router radio from the computer that is connecting? (Login to the router's setup page at 192.168.1.1 or 192.168.0.1 (depending on the router) and go to Advanced menu and click Wireless Settings.) While you are there, enable the SSID Broadcast (another checkbox hust below the one for Wireless Router Radio). Now check if your laptop can see the router.
Additional FAQs that might be helpful are at http://kb.netgear.com/app/products/model/a_id/2589. That page has a link to setting up XP for wireless networking as well.
Aug 11, 2009 | NetGear WGR614 Wireless Router
My netgear wgr614 is not working. I have no
To establish a wireless connection between the router and computer, the router’s wireless setting (SSID or Network Name, Channel, and Mode of communication) has to be configured. Please follow the steps below to configure the wireless settings on your NETGEAR router.
  1. Connect a computer to the LAN port of the router using an ethernet cable.
  2. Open up a browser and type in the following URL: http://192.168.0.1 or http://192.168.1.1 (depending on the model number of the router)
  3. Type the Username as admin, and Password as password. Then click OK.
    1. To change the Wireless settings, click Wireless Settings under Setup on the left menu bar.
  1. Under Wireless Network, (make a note of these settings, you need these values to configure your wireless clients)
2.
    • Change SSID from default NETGEAR to any desired name (for e.g. Home)
    • Select the Region as applicable - Incorrect selection may cause performance problems.
    • Select any one of the available Channel.
    • Apply the changes
Configuring Wireless Clients:
The steps explained below use the Windows XP wireless client. If your card came with
its own wireless configuration utility, you may use that as well.
  1. Open the Control Panel from the Start Menu.
  1. Right-click Wireless Network Connection and choose Properties.
  1. on the Wireless Networks tab and if unchecked, check the box for Use Windows to configure my wireless network settings.
Then click OK.
  1. Right-click on Wireless Network Connection, Select View Available Wireless Networks
  1. This will lists all the available wireless networks in range. Select your network from the list and click Connect.
If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key (if you are using WEP security, make sure you are typing the network key, not the Passphrase) and click Connect
  1. Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wirelessly.
May 18, 2009 | NetGear WGR614 Wireless Router
Netgear wireless router DG834PN wireless access local only I can get internet on my desktop which is connected to the router via ethernet but I can connect to the router wirelessly on my laptop but only...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To start with plug the LAN cable, type 192.168.0.1
into your browser, a netgear window should come
up name is (admin) PW is (password) default.
goto to wireless settings.
Tick Enable Wireless Access Point
Tick Allow Broadcast of Name (SSID, give it a name
Under security options, Tick none
Hit apply and exit
Setup your laptop up with no security to start with, the laptop
Should now see the Netgear SSID name you made.
After this find out your laptops MAC address, log back onto the
Netgear unit, add the MAC address to the allowed list, hit apply
And exit, now only your laptop will be able to get a wireless connection.
Hope this helps
Have a nice day
Aug 14, 2008 | NetGear WGR614 Wireless Router
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Router Logo
182 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
