The speaker for the mic has been damaged due to the water.
speakers and water dont mix too well. if you want to continue using it you will have to replace it yourself, or pay your service provider to do it for you. may cost a leg or 2
ebay is famous for finding parts for anything, type in your phone and model and the part your looking for. with a little ambition, research and a torx set you can take the phone apart and do it yourself !
let me know how you make out
We charge $25 for Cell phone
Cellular Phone'); return false">Cell phone Microphone Repair service and an additional $10 for liquid damage
Also referred to as Water Damage. Usually when a cell phone is exposed to any kind of liquid such as water, soda, coffee etc... which causes the cellphone to malfunction, it is said that the phone is Liquid Damage'); return false">liquid damage cleaning plus parts. Your mic might be simply shorting out because of the residue left from the water damage
Also referred to as Liquid Damage. Usually when a cellphone is exposed to any kind of liquid such as water, soda, coffee etc... which causes the cell phone to malfunction, it is said that the phone is Water Damaged'); return false">water damage
or it might have gone bad. No way to tell without having the
technician take it apart and diagnose it. Simply click on the link
below and purchase the repair service and send the phone in and we'll
let you know once we have checked it out. Here is the link:
http://www.cellulardr.com/Cellphone-Speaker-Repair-Microphone.htm
Thank you for the opportunity to repair your cell phone.
Well if a microphone is exposed to to much vibration shock it can shatter the diaphragm that is in the microphone, which is crucial to how it works. In my opinion I would attempt to use the fan trick, and if that does not work I would call the phone manufacturer.
Ryan Frame
Creative Energy Associates Technical Center
Head Service Technician
Hello kent581,
take out the mic and dry it properly. make sure it is completely dry with no moisture, then reassemble it. If you are lucky, it will work again as long as there are no bridging of cables by the liquid that got into it. If it does not work, you may have to get another mic to replace it. cheers!!!
I have already run it under 2 fans for an hour, it works because I can hear it produce very loud noises faintly. I need the microphone to work @ normal sound levels.
the phone is 2 days old, it hasn't been dropped yet, I am not certain if it could sustain a shock in the pocket while in the washer. We have the new style low impact washing machine. I would like to know what I can do to make this microphone work.
