Question about Whirlpool Ultimate Care II GSQ9669L Top Load Washer
No rinse or drain - Whirlpool Ultimate Care II GSQ9669L Top Load Washer
  • 5,911 Answers
If the washer does not rinse or drain, this is commonly caused by a lid switch malfunction. Sometimes, all that is required is to tighten the mounting screws that hold the switch in place. If the switch is definitely broken, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 11, 2009
GE Dishwasher leaking
HI,
If you're just looking at the machine the problem is not going to be fixed..
and now the question: in witch cycle is leaking?
fill, wash or rinse?
can be...for fill...one hose from filling is broken.
for wash...mechanical seal from wash motor, the plastic manifold,one gasket.
rinse..manifold or hose for the rinse...rinse pump..
for drain..solenoid for drain, the hose for drain..
Anyway you must open the machine first of all and see.
Good luck
Jun 30, 2013 | Dishwashers
It will not drain the water on the rinse cycle
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 24, 2010 | Maytag Washing Machines
NOT DRAINING AFTER RINSE CYCLE
Dishwasher is not filling in first cycle. only in rinse cyle then it won't drain it
Jul 31, 2009 | GE Nautilus 24" Built-in Dishwasher
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
check the drain pump
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Whirlpool Ultimate Care II GSQ9669L Top Load Washer Logo
121 people viewed this question
Dan Webster
Dan Webster
Sal De
