Back to:
Tags:
Refrigerators
Generic problem for all Refrigerators
Fridge not cooling (by 2 users)
posted by fridgeprob on Oct 13, 2007
I cleaned out my fridge Thurs night (today is Sat, Oct 13) and now it doesn't seem to be cooling.  I had the door open about an hour.  I didn't hit any switches - just did the cleaning.  The light is on and the freezer seems to be fine.
What am I missing?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Simno, posted on Nov 15, 2007
F&P two-door Model N510TGRWWWWV819 - FREEZER WORKS NORMALLY, FRIDGE FAN IS GOING CONTINUOUSLY, BUT NOT COOLING REFRIGERATOR.
Best Solution
posted on Oct 14, 2007
FixYa! (100)
Premmy
Rank:Guru Guru
Rating: 86%, 65 votes
It might be that the fan motor somehow got disconnected or worn out, or that the fan itself is stuck.  It’s located in back of the freezer.  Gently unscrew the back and check it out.  You might also have to unscrew the thermostat housing if it is on the top of the fridge part.  If the fan is turning, it’s okay.  If not, turn the thermostat down to its lowest setting and see if it turns on.  If not, unplug it and test it with a continuity tester.  If, there’s no continuity it will need to be replaced.  Good luck.
Rating Locked! (?) fridgeprob has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on fridge not cooling:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Refrigerators
the fridge is constantly leaking water from inside. Just...
Refrigerators
Freezer TF775a, Ser No 6450085, Prod No 9224814. Upon...
Smeg FC40RX Bottom Freezer Refrigerator
I have a smeg FC40RX frigerator and on the frame where the...
Refrigerators
i need to replace an internal glass shelf
Refrigerators
no power from top circuit board
Loading problems.
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
