Question about KitchenAid KAWS850L Top Load Washer
Trying to replace clutch on kitchen aid clothes washe, cant pull gearcase off . have moter removed already.
  • KitchenAid Master
  • 3,361 Answers
There are 3 bolts holding the gearcase on. Remember to remove the agitator from the tub first.
Posted on May 11, 2009
Our Kenmore (11020722990) spins very slowly no matter the load size. The clothes come out soaking wet. Any suggestions?
The clutch is likely worn or has oil on the pads. You will need to replace the clutch assembly, available HERE. The clutch is accessed by removing the gearcase assembly.
Jan 13, 2011 | Kenmore Washing Machines
How to remove the drum from a kitchen aid washing machine
hello. Unplug the washer and use a vacuum cleaner to remove the little balls. J.
please rate my answer as very helpful. Thanks.
Mar 28, 2010 | KitchenAid KAWS700L Top Load Washer
Agitator does not spin.
The clutch needs replacing. The gearcase needs to be removed and the centrifugal clutch is mounted on the gearcase.
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
I am trying to replace a clutch assembly
agitator needs to be disconnected, then tilt machine back disconnect pump and move out of the way. take 3 bolts holding the gearcase out an remove gearcase. Motor does not need to be removed unless you are going to replace the coupler. At the top of the gearcase there are 2 clips that need to be removed and wala, the clutch is easily taken off. reverse procedure, and reinstall gearcase. Be sure to rotate the brake and push up into the bell housing. if the brake comes down at all the gearcase won't reset into place. Good luck. There are detailed pics of this operation on the samurai appliance guru web site.
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
How to replace the gear case for whirlpool washer lsn1000kq0
remove 2 screws on rear of console lift console forward and roll back remove the lid switch connector remove the 2 clips on each side pull rear of cabinet forwardand slide cabinet off remove screws in center of agitator under cap and pull off ..lean washer backward remove pump clips and hoses remove 2 screws in motor clamps remove clamps and motor remove 3 1/2 in bolts holding gearcase to bottom slide gearcase out remove clutch and reinstall on new gearcase if you go slow and take note reassembly not that hard
Nov 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Cannot remove clutch from gearcase
there is a spring clip under the washer and C clip slid screwdriver under it to remove it no clutch does not come with gearcase..clutch pt #285785
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer won't spin
most likely just clutch ck for oil or water on it if oil most likely top seal gearcase is leaking ..remove agitator cap remove bolt in middle of agitator ..remove console screws remove clips under console holding cabinet on remove cabinet ..lean washer back remove pump then motor remove the 3 bolts holding gearcase in remove gearcase clutch is silver disk on top of gearcase with band inside ..band is actual clutch may try cleaning it but not hopeful about it being a permanet fix
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II washer won't spin clothes more dry than soggy
Tip the washer backward, inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin. The gearcase and clutch will have to be replaced if oil is present. Check the owners manual for limited warranty on the gearcase. If oil is not present, the clutch is just worn and should be replaced.
Oct 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kemore washer MD#24902200
This problem can be attributed to any one of the following items:
1. Worn Clutch/Brake assembly.
2. Gearcase (transmission) starting to go bad.
3. Basket Drive assembly worn or loose.
The more common problem is a worn clutch assembly, but you can't always be sure. If the gearcase fails, a common tell tale sign is a light colored oil leaking from it. You will notice puddles under the washer and/or spray pattern marks along the interior walls of the casing. Sometimes these two problems are interrelated as oil leaking from the gearcase can cause the clutch or brake to slip.
The following link explains how to replace the gearcase assembly:
http://www.fixya.com/support/r699497-replacing_gearcase
I'm not saying you have a bad gearcase at this point, but include this link because it gives information on how to remove the clutch/brake assembly. If you go to searspartdirect.com and type in your model number as "110.24902200" there are some very helpful drawings under the "Brake/Clutch/Gearcase/Motor/Pump" heading. The gearcase is listed as item 9, the entire clutch/brake assembly is listed as item 5. The Basket Drive is listed as item 1.
This problem can often be hard to diagnose as any one of these components mentioned can cause a slow spin problem. I would recommend you remove the outer casing and do a visual inspection of the gearcase and clutch assembly (under the wash tub), first. Let me know what you find. I hope this gives you some guidance.
PS A basket drive failure will require you to remove the wash tub to replace. Since the basket drive penetrates through the bottom of the wash tub, it is recommended that you also replace the wash tub seal. Let me know what your preliminary findings are before we touch on this topic.
Aug 28, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer
If your washer is not spinning fast enough, or barely spinning at all, this is usually a symptom of any one or all of the following: 1. Bad gearcase (transmission). 2. Bad basket drive, with which the transmission couples to under the agitator. 3. Bad clutch/brake assembly. Which mounts on top of the gearcase under the basket drive. Usually a tell tale sign of a gearcase beginning to fail is the sign of an amber colored oil coated under the washer or inside the casing. I said, "usually". It doesn't always happen, but if you notice any signs of oil, the gearcase is shot. The basket drive and clutch assemblies are harder to diagnose and require some disassembly of the washer and the removal of the gearcase to inspect. Let me know if this helps.
Aug 01, 2007 | Kenmore 22642 Top Load Washer
KitchenAid KAWS850L Top Load Washer Logo
138 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
