Question about Sub-Zero Bottom Freezer Refrigerator
Bottom freezer is very hard to open. Is this normal ?
I have a Subzero 650 and the bottom freezer is very hard to open. It feels like there is a suction when I attempt to open it and it takes two arms and a strong tug. Is this normal ? I didn't think a freezer would be so hard to get into .
  • 725 Answers
Yes this is normal... you can turn the temp up ... the suction is caused by the diffenence in temps from the room and the freezer...
Posted on Sep 19, 2009
Subzero 650 bottom freezer is pooling water under the veggie drawer
Check you your drain line behind the 2 bottom drawers. Most likely it's clogged. You can try snaking it out with a single foot wire. See if the water goes away from the trough.
Smith Brother Appliance Repair reviews
Apr 12, 2011 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 has melted and refrozen cubes under normal cubes - I have emptied the ice cube tray three times, made sure it is dry before putting it back, and each time there is eventual frozen water...
maybe the water valve keep open. try replace the water valve. the ice maker energized the water valve. and release water. MAYBE in each cycle after energized the valve this one keeps open. ttry replace is really simple..... good luck...... leave a comment if it this good for you
Jan 12, 2010 | Sub-Zero 650 / O Bottom Freezer...
Subzero 601R Extremely Difficult to Open
This is a problem with freezers that have their drain outlet blocked.
Clean the doorseals anyway with a warm cloth and soapy water, then remove inner drawers. There should be an access panel at the rear to remove, and this will reveal the cooling coils and the drain at the bottom of these. You will need a short length of wire to clear the pipe. Make sure power is off while you do this.
Sep 26, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero freezer drawer left partially open- went into shutdown. This has happened before, and there was a trick- like turn the freezer control to 1 for twenty-four hours, then up to 3 for twenty-four...
unit is most likely frosted over. bets thing to do is turn control for freezer to off for 24 hours, put down some towels for the water and prop the drawer open at least 6 inches. Then turn back to normal setting and allow 12 hours minimum for normal tenperature
Jul 17, 2009 | Sub-Zero 650 / O Bottom Freezer...
I have an older model subzero (refrigerator on top and a single drawer freezer on the bottom) which, when the bottom drawer is opened, leaks water. What to do?
Honestly I can't think of any cause for this that wouldn't require a qualified servicer. Most likey one of the drains is blocked and they make heaters to correct the issue
Jun 09, 2009 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
Sub zero bottom freezer access
that unit must be 20 plus years old. There wouldn't be any diferent shelves available for it.
Jan 31, 2009 | Sub-Zero 650 / O Bottom Freezer...
Left Door open now it wont power up
you can un plug it for 30 minutes to an hour and plug it back.
hope it would run normally.
tnx 4 using fixya,
drcool
Sep 27, 2008 | Sub-Zero 650 / O Bottom Freezer...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero Bottom Freezer Refrigerator Logo
159 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
