Question about Maytag Refrigerators
No water coming out of matag model MFO 25 60hes--
Button is on the left had side inside of the door---when you push it you do not hear the solonoid nor do you have any water coming out.
    Sergeant:
    Champion:
  • 219 Answers
Yuo may have a bad microswitch on the dispensor arm you may want to cheak that out.it would be normaly open or normaly closed on the switch may need a ohm meter.
Posted on May 11, 2009
No water through door - PSS25MGMA WW - replaced water bracket and valve assembly - GE Profile Artica
Since you have already replaced the water inlet valve , at the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is also a water dispensor heater kit , pt # WR49X10173 , which comes with installation instructions .
Nov 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
KitchenAid side by side model # KSRS22QFAL00 not getting water through the door. some water to ice maker.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
OR
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Sep 10, 2009 | Refrigerators
My Maytat side by side with ice/water in the door is stuck on the water and will not push to the ice setting?
This is probably your switch or the button is frozen in the water position. I would check the ice dispensor inside the door first and see if there is ice built up on it. If so, you can run warm water over it with a pan under it to catch the water. If this is not it, call us and we will ship the switch to you. We will need your model number. Hope this answers your questions and resolves your issue. :>)
Aug 25, 2009 | Maytag 23 cu. ft. Side-by-Side...
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchen aid refrigerator water dispenser does not dispense water. the ice will dispense, and there is no filter for the water, so i would assume no clogging is the issue. But any ideas would be appreciated...
could be a few things. fist, when you call for water, listen for a very faint "hum" noise, if you do hear that, it is either the solonoid on the valve, or the reserve tank in the frige froze. easy way to check. pull the frige out and un-plug from power. on the back of the unit is a cover on the bottom, remove cover. the valve is on the far right as your looking at it. it has 2 solonoids on it. there are two plastic water lines on the bottom of the valve, i believe the one on the left is for ice maker, and the right one goes to door dispenser. remove the water line going to the door dispenser and put a cup under the valve. plug in frige and call for water at the door for couple seconds, check to see if water came out of valve into cup in back. if it did, the valve is ok, if no water, replace valve. they run about $50. if you didnt hear the hum i talked about, and the valve is ok, let me know and i can walk you through checking and replacing the switch in the dispenser. good luck, shane
Aug 24, 2009 | Refrigerators
Water is not dispensed when the dispensor is activated. Only a clicking noise under the fridge can be heard. model srd2555w
When you try the water dispenser you should hear the water inlet valve which is on the back where the water supply comes in. If you do hear it then Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
If you don't hear the valve working the dispenser switch is bad.
Aug 16, 2009 | Amana SXD524VW Side by Side Refrigerator
I have a side by side GE profile Artica refridgerator. The Ice maker is producing, but I cannot get water to come out. When I push the water dispenser, I can hear something happening, but nothing comes...
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My side by side whrilpool refreg
First of all, is there a reset button that needs to be pushed after changing filter? Mine has one. Check around the sides and top inside the fridge for a little button and push it in.
Is the water turned on going to the fridge?
If it was working before you changed filter, maybe the water line got kinked somewhere and no water can come through.
Also, if filter isn't reinstalled correctly, no water can come through it. Make sure the filter is not upside down and that the holder is screwed in all the way.
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Thru door water dispenser not working
Hi jkalmada,
I will give you an easy way to test your refrigerator to find out if the water solonoid is defective.
In the back of the refrigerator you will see a small plastic and metal item called a double inlet valve. The water line from the wall will conect to this item. To check this all you need to do is pull the plugs off of the unit and reverse them. This will cause water to go into the icemaker when you push the water button on the door. If water will fill into the icemaker when you push the button then the solonoid is bad, and will need to be replaced. If no water goes into the icemaker when you push the botton the the switch behind the button is bad. NOTE, be sure to put the plugs back on the correct side of the solonoid after testing, or you may have some water problems.
One other solution that can happen. If the water in the cooling tank behind the crisper drawer is frozen then the water will not make it to the door, so make sure it is not frozen. and the only thing left that can cause this problem is the water filter, but if it is making ice, the problem will not be in the water filter. If you have anymore questions please give us a call Monday thru Friday 9-5 EST.
Anderson Appliance
Michael Anderson mca0824@aol.com
(865)945-3808
Aug 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
