Power supply replacement help
I need help tp replace the power supply on my Samsung TXN3075WHF. Can you talk me through it? I dont know where to start.
  • pat_saum May 15, 2009
    I am getting a split second of sound, no picture. I hear 3 clicks then it shut itself off. I replaced the fuse and checked the caps but dont see any bulging there. Could they go bad withoout any physical signs? Any other suggestions would be great.
  • 107 Answers
SOURCE: screen replacment samsung sgh j700
goto an ebay shop and they have manuals there
4onesexpress-07802458019
Posted on Dec 02, 2008
antiochpc
  • 1314 Answers
SOURCE: replacing power supply HP M8120N
Here is the link for the upgrade and service guide.
This one is just as easy as 1) removing the side panel; 2) Remove the four screws that hold the power supply into position; 3) Remove the power supply cables from the motherboard (NOTE: If the media bay reader is in the way, you remove the front bezel by pressing the release tabs on the bezel and it will swing open. Remove the one screw securing the bay in position, then slide it forward so you can reach the power cable to the motherboard.); 4) Remove the power supply cables from the hard drives, cd rom drives, and other peripherals inside the PC. 5) Remove power supply...sometimes there is a button to push and it will slide out, sometimes not. 6) Replace power supply, then reverse procedures.
Thanks and please take a moment to rate as fixya.
Posted on Dec 07, 2008
  • 12 Answers
SOURCE: tp sensor replacement
it should be on your throttle body under the hood of your car
Posted on Apr 06, 2009
SOURCE: need to replace a Lite-on power supply
No really a solution. Could do we someone just saying where a Liteon PS-5221-06 power supply could be bought from. That would be the actual answer to the question!
Posted on Feb 10, 2010
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
My Samsung TV model number LN-T4032H turns on fot a while then shuts off by its self but sound stays on, i dont know what's wrong with it, anyone know why?
The power supply in this TV uses poor quality electrolytic capacitors which dry out over time and become faulty. They need to be replaced by someone who knows how to repair circuit boards.
Apr 18, 2016 | Samsung Televison & Video
Ii replaced all the parts in my percision analog power supply i dont know how tp reconect tbe wires can someone help me
I'm not sure what that is but I would probably go online to find the answer you will probably have to take it to a place where they know about these things or just DIY (do it yourself)online.
Apr 28, 2015 | Power Computers & Internet
Side of picture screen are wavy
Check all the electrolytic capacitors in its main power regulator section circuit. Replace them.
Jan 25, 2013 | Samsung TXN3075WHF 30" TV
How do i change fuse for txn3075whf
Inside of the TV usually near the power cable on the PCB. If you don't know what you're doing get it repaired.
Dec 29, 2012 | Samsung TXN3075WHF 30" TV
My samsung le37r88bd suddenly went dark and now needs the brightness turned up full also any text stays superimposed in the background for a while
sounds like text is staying on screen because you have brightness turned up too much
the reason it is dark is probably because backlight is bad - backlight is flourescent bulb and if you have ever seen a flourescent bulb you know how it gets dark from edges almost as soon as you start using it
you might be able to replace bulb yourself if you are handy or bring in for service
there is a chance (possibly a good chance) that the power supply for the backlight is bad also - you might want to consider if a repair is worth it considering how cheap they sell these things now
let me know if i could be of more help
good luck!
Mar 24, 2011 | Samsung Televison & Video
Relief valve on my water heater is dripping.Can I fix this?
There are two solutions:
1) Replace TP valve with same temperature/pressure as existing TP valve.
Buy the TP valve at hardware store or home center or plumbing supply.
Turn off water heater so water cools.
Hot water inside a tank is explosive ... so open the TP valve and test water temperature.
If TP is on top of tank, you don't need to drain much water before unscrewing
If TP is on side of tank, use the TP valve to drain water -or- use the drain valve
Unscrew TP to remove.
Put teflon tape on new valve threads so it will seal against leak.
2) If the new TP replacement starts doing the same thing, there may be a thermostat problem -or- thermostat is set too high.
If you keep the water temperature set high, you can add expansion tank to incoming cold water line.
Home Depot sells expansion tanks. Plumbing supply carries them,
The tank for residential water heaters is about same diameter as a football and it goes on cold water line.
Oct 31, 2010 | Water Heaters
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
I have a Samsung TXN3075, makes great video from laptop or cable input...for about 5 minutes, then its good audio, black video, until it cools down then it will work a bit. Could someone give me a bit of...
The screen is overheating, due to either a malfunction or poor engineering/assembly. It shuts itself off (as it's the HOTTEST part of any TV) to keep itself from basically bursting into flames.
Contact the manufacturer and have their tech support guys help you out with it. They may have other similar cases and perhaps even have some sort of warranty extension/free replacement based upon that specific problem.
Jun 04, 2010 | Samsung TXN3075WHF 30" TV
Power turn-on after 5min.s cut off power
chek for leakage capacitors.hope thisn will help
Jan 19, 2008 | Samsung TXN3075WHF 30" TV
Bad picture
Hi Dan,
It sounds as if you have a bad filter capacitor in your power supply. Check the main filter caps rated at 150 volts and above. It's likely one is leaking and need immediate attention. I hope this helped. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Samsung TXN3075WHF 30" TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
