Question about NetGear DG834G Router
No KAD network on emule lo id?
Hi! I am blocked on the KAD network on emule.
I have low id.
I have configured my to ports to be allowed but no luck,
help
thanks
  • 196 Answers
Did you change the standard ports?
This site has excellent instructions:
http://www.portforward.com/
Posted on Oct 14, 2007
2 Suggested Answers
hughv
  • 196 Answers
SOURCE: kad network lo id
Did you change the default ports?
This can be tricky, but there are excellent instructions at:
www.portforward.com
How to forward port to get high ID in emule
Here is how to set up port forwarding for emule: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule.htm If you use emule Plus see here: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule_Plus.htm
Jun 07, 2009 | Linksys WRT160N Wireless Router
Saving port forwarding configuration
To make the change permanent, click Tools and select System commands,
on the system commands click save all.
Aug 26, 2008 | Cnet Wireless-G CAR-854 Router (CAR854)
Change low Id High ID using eMule
Where are you Santiago, and Emule is still having conflics with its scripts, just change to a another Source, I will pull itup later on tonight and see where the Problem is,...
Aloha
Kahuna
May 28, 2008 | Computers & Internet
Emule Show Low ID on Client Computer
Dear sir/madam,
You can update the servers it may be become fast. Go this site and add all servers (add to emule) click this link, they automatically update the servers.
http://ed2k.2x4u.de/index.html
OR try this
First of all you need to know the IP of the computer that you use with Emule.
Then go to the router configuration:
- Choose "NAT Settings", and "Virtual Server".
1- If it isn't enabled, enable the "Virtual Server".
2- In "Well-Known Applications" choose de option "User defined".
3- Now the crucial part. Under the Virtual Server List, in the "Local IP" you place the IP of your computer (on the example, 192.168.1.2, i.e. my emule computer ip), "Port Range" put 4662 and Protocol TCP. "Protocol nº." stays blank, and in the "description" you can put Emule Rule Nº1.
4- Click ADD, to add the rule to the table.
- Again you make the same passes from 3 to add the second rule:
3- In the "Port Range" you place 4672 instead 4662, and on Protocol you place UDP instead TCP. On "Description" you can place Emule Rule Nº2.
4- Click ADD.
5- After making the 2 rules, click Finish, and on the next screen click on Save&Restart button.
In the next time you start Emule, you can acess to the servers without Low ID.
Don't forget to rate the solution
thanks
Mar 23, 2008 | Computers & Internet
Kad network lo id
www.portforward.com
Oct 13, 2007 | NetGear DG834G Router
Emule lowid
I am sorry, but I would not listen to advice that you need to disable your Firewall for it to work!?!
Obviously as the response shows, even with the Firewall disabled it did not work [and would be vulnerable to attack]
There are two possibilities off hand:
  1. You have not taken into account forwarding ports in your Router as well as Software Firewall [if applies to you]
  2. Your ISP may be aware of using the ed2k protocol and try to stop you from using eMule
Remember to use the OBFUSCATION option.
This option in eMule allows you to connect to a server in a way
that masks or 'hides' the ed2k (eMule) protocol
Go To Options > Security
Here you'll tick the "Enable Protocol Obfuscation" box
Remember to only tick the first box under "Protocol Obfuscation"
You should be able to see your 'hidden' status on the right side
of the server window in eMule
If your ISP was in fact interfering, this should help you gain back your ability to use eMule without restriction
Oct 06, 2007 | D-Link DI-707P Router (DSDLDI707P)
How to port forward using Dlink DI-524 for Emule?
DMZ is a feature that is included on some routers but is not in Internet sharing software. A DMZ allows a single computer on your LAN to expose ALL of its ports to the Internet. When doing this, the exposed computer is no longer ?behind? the firewall. Port Forwarding vs DMZ A DMZ is far easier to set up than port forwarding but exposes your entire computer to the Internet. Sometimes TCP/IP applications require very specialized IP configurations that are difficult to set up or are not supported by your router. In this case, placing your computer in the DMZ is the only way to get the application working. Placing a computer in the DMZ should be considered ?temporary? because your firewall is no longer able to provide any security to it.
Oct 03, 2007 | D-Link AirPlus DI-524 Wireless Router
Low ID on emule when am using Belkin F5D7230-4 router
You need to find out what port Emule uses for sharing, then enter the port number in you routers Firewall Virtual Servers menu in the settings and enable your pc's ip address to accept inbound connections.
Jan 20, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Low ID on eMule
One more thing re low id on emule - try to choose ports between 10000 and 60000 - many isps block the standard ports that emule users choose, and you will see people saying to choose one over 5000, but I'd chosen ports between 5000 and 10000, and still had no luck until I went over10000.
Most isps don't monitor ports over 10000, so if you still have low id problems even after port forwarding and setting up your firewall, this may be the answer to your problem! (I got this info off portforward.com, and it worked for me)
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
Configure for emule
You must open ports on your router to allow incoming traffic while using eMule. eMule uses three ports*: 4662 (TCP) 4672 (UDP) 4711 (TCP) Visit eMule here. * To prevent getting a low ID (Firewalled), open additional TCP ports between 4661 and 4665. Also, limit the number of connections in the eMule software. You may need to change the TCP Clientport to something other than 4662.
NetGear DG834G Router Logo
748 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
