Question about Frigidaire FRS26R4A Side by Side Refrigerator
Showcase freezer fan motor makes constant clicking noise
The freezer works fine just makes loud clicking noise. the fan is not hitting anything. The second I kill the power the noise quits. If the fan motor is making the noise would the noise still continue with no power and the fan still turning? The fan does have play in it from in and out, not a wabbly play. Could this be a bearing in the fan motor? Also can a freezer compressor motor be used for an air compressor?
    President:
  • 1,489 Answers
I have seen this specific problem. and I solved it.
It's the fan "bouncing" against the motor housing. Nothing wrong with fan -- design flaw. The way I solved this problem was to shim the fan mount so the fan was at a slight angle off level -- this keeps the shaft from moving in and out and the fan banging against the housing.
Here's a link discussing your queston about making an air compressor from a refrigerator compressor.
http://www.volksrods.com/id36.htm
Posted on May 12, 2009
  • Samuel Charles Spriggs May 13, 2009
    Did you try the shimming suggestion?
    Sergeant:
    Champion:
  • 219 Answers
Is the noise clicking consistantly?or just on again off again?Yes there may be a faulty motor.Try removing the wires and tape them up then run the unit if there is still noise need more info .And to let you know yes they can be made into a low quality air compressor:) hope i helped :)
Posted on May 11, 2009
Whirlpool Side by Side. Husband replaced fan motor inside freezer. Ever since it's been replaced, it runs frequently and hums loudly. Any suggestions. He took the interior back out and it doesn't hum.
The fan blade touching the interior back cover????
May be the fan motor shaft is too long or may be he did not push the fan blade well inside into shaft so it is to much out. Thus touching the wall cover plate..????
Sep 24, 2014 | Whirlpool Refrigerators
Fridge makes very loud noises when door is closed and motor is on. When the door is opened the noise stops. It sounds a bit like machine gun fire or the motor is about to give out. Do you know what the...
Initially, would suspect the evaporator fan blades hitting something or a misaligned vent. Pls post back the make & model.
Other areas to check would be:
  • loose covers, flaps or anything outy of the ordinary;
  • compressor support;
  • condenser fan (at the rear) if present;
  • anything else that could be checked visually.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 26, 2008 | Refrigerators
The feezer side is making a loud noise and will not stop. it seems to still be cooling just fine on both sides. thier is no burning smell or anything. i tried dissconnecting the ice maker and that did...
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
Jul 31, 2011 | Frigidaire Refrigerators
At first the refrigerator side was freezing everything and the freezer was fine, except the ice & water quit working. I replaced the filter & it worked for a few days then it was back to the same...
if the fan was loud you could have a bad evap fan motor,is there ice on the inside back wall of the freezer?if there is you have a defrost problem and ice could be built up around the fan motor and the blade,when the blade hit the ice that could be the noise you were hearing and now the ice is stopping it from spinning at all.if there isn't any ice on the wall you could have a bad computer board,part number wr55x10942,i've seen g.e.'s that when the water and ice didn't work and the temp was warm it was the board but when you say the fan was loud it makes me think you could be iced up in there.also if the fan motor was reving up and slowing down the board could cause that,let me know if there's like snow or ice on the freezer wall and i can help you out
Sep 30, 2010 | GE PSS26LGR Side by Side Refrigerator
My refrigerator makes a loud humming sound.
sounds like its bearings in a fan motor probably your evaporator fan motor it is located behind the plastic shell in your refrig. you have to take out the lining and then you will see the fan, evapartor and etc.
Jul 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice on refrigerator motor?
The fan in question is the evaporator fan motor and is hitting the ice. The problem is the freezer is not going into defrost due to a faulty defrost thermostat , heater, or timer. You have to call them back out free of charge on there 2nd time out and have them repair it right.
Sincerely,
Shastalaker7
Dec 30, 2009 | Fisher and Paykel Active Smart E522B...
Making a loud noise
yes. is the fan hitting ice. the fan activates when close the door the upper baskett press the fan and light switch............... good luck.......... LEAVE YOU COMENT IF IT WAS GOOD FOR YOU
May 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Fan making loud noise like its hitting against something
take and defrost the unit and make sure that the drain line is clear. this should solve it. Thanks for using FixYa.
Dec 25, 2008 | Freezers
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Intermittent Loud Whirring Noise
sounds like the evaputaor fan motor.. may need to replace.. check to see if anything maybe hitting fan blades
Sep 30, 2007 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
600 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
