Question about Samsung RS2630SH Side by Side Refrigerator
CENTER METAL SURFACE THAT DOOR SEALS TOUCH WILL BURN YOUR SKIN
SIDE BY SIDE MODEL # RS2630WW CENTER STRIP SURFACE WHERE BOTH DOOR SEAL STRIPS CONTACT JUST STARTED GETTING SO HOT IT WILL BURN THE SKIN OF MY HAND & FAN WAS GETTING NOISY ITS DONE THIS BEFORE, AND PLEASE DONT SAY THIS IS NORMAL, NORMAL WOULD BE A LITTLE WARM THIS IS XTREMELY SCALDING HOT AND IS ALMOST MELTING RIBBER SEALS. LAST TIME I UNPLUGGED & RENTED A FRIDGE TILL REPAIRS WERE DONE BUT IT RAN OK AFTER SITTING ON BACK PORCH WITH BOTH DOORS OPEN FOR A COUPLE OF DAYS, I AM A LAUNDRY TECH SO i CAN REPAIR IF I KNOW WHAT TO REPAIR...HELP !!!!!...PLEASE
  • Anonymous May 17, 2009
    same problem!
  • hai nguyen May 21, 2009
    i have the same problem go to partstore buy the part # DA97-01949A and easy fix when you waiting for the part you can use the fan let it cool down and every thing be fine
    Problem Solver:
  • 5 Answers
Yes, this is the fan problem. Easy fix with either new fan blade ($2.95) or new motor and fan ($35) from partstore. Call them if you're not certain about what part. Good company.
Posted on Jun 23, 2009
Go to partstore buy the part # DA97-01949A and fix it you can put the fan in back refrigerator keep it cool when the part come and fix it
Posted on May 21, 2009
Why is the strip between the two door very hot
perhaps it is the defrost heater . it could be the door seal is bad in that area .
Aug 30, 2015 | Refrigerators
Why does it get very hot around the door's perimeter?
The door is heated so it doesn't stick shut with ice. It may be that the condenser is clogged or the fan isn't running, causing excessive heat in the strip. Clean the condenser thoroughly and check the fan.
Jul 01, 2012 | Kenmore Elite Side By Side Refrigerator -...
How to you replace the freezer door seal
is it a latched door, if so weather stripping (high density foam) is a good alternative, commonly used on edges of doors, believe it or not that is a door seal just without the cover to make it more pleasing to look at, it comes in various depths, sizes and is normally two sides adhesive. if it is a magnet strip type; pick a side and use it as a strip magnet surface or cover it.
Oct 14, 2011 | Frigidaire 20.6 cu. ft. Top Freezer...
I have a Samsung RS2630WW Side by Side refrigerator. The center column dividing the freezer from the refrigerator is very hot to the touch. The freezer and refrigerator are working fine. Is this a...
Hi, Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor.
The amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward.
Please take a second to rate the info provided here.
macmarkus :)
Aug 13, 2010 | Samsung RS2630WW Side by Side Refrigerator
Why wouldthe center piece between freezer & refrigerator get hot
There is a heater located behind that strip known as the mullion heater.
Look to see if you have a switch labeled "anti-sweat"
Apr 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
How do I change the headlight bulb in my 1997 thunderbird?
Access the headlight bulb from under the hood. There should be a clip (screw on or snap) holding the bulb in place. Carefully unplug the socket from bulb and remove clip and slide bulb out. Installation is reverse of removal. Be careful NOT to touch the glass surface of the new bulb, as the oils from skin can cause it to shatter when heated.
Feb 15, 2010 | 1997 Ford Thunderbird LX
89 jetta carat rubber frame passenger door
use weather stripping glue check with auto zone
Oct 16, 2009 | 1989 Volkswagen Jetta 2 Door
Divider between freezer and fridge is HOT to the touch
That is a heat strip to prevent condensate near the door seals and yours is possibly shorting out because the control fo it is defective. Send me the model number for your Roper and I will look at the diaqrams to confirm my theroy. Thanks, Sea BreezeEnter your model number at the link below and it will take you to the parts and photos.http://servicepartstec.blogspot.com
Jun 05, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Outside of refrigerator is hot - almost burning hot
The frame between the doors has a refrigerant line running through it to prevent moisture build up between doors (should be room temp. or slightly warm, not hot).
If that area between the doors is hot to the touch, you have two things to check: 1 - are the condenser coils under unit or in the back clean? 2 - is the condenser fan running in the back that is near the compressor running?
Aug 24, 2008 | KitchenAid KSCS25IN Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
368 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
