Question about Singer Featherweight 132Q Mechanical Sewing Machine
The needle on my Singer 132Q featherweight breaks everytime it goes down, i took apart the bobbin holder and such and i can see a part that has little marks in it from the needle. it cant be that the needle is bent because iver replaced the needle every time it breaks.
  • 128 Answers
Sounds like it is out of time. I recommend you take it to your local repair center.
Posted on May 12, 2009
I received a 221 singer feather light as a gift.... Love using old machines. It will not pick up the bobbin thread. When it cycles the top thread hangs up and breaks.
Lucky you!
First thing to always try is a brand new needle. A lot of sewing machine problems are due to an old, dull, bent needle.
Most likely the machine has been knocked out of time--the needle and hook are out of sync. Search for sewing machine timing or take it or service.
https://singer-featherweight.com/blogs/schoolhouse/how-to-thread-a-singer-featherweight
Dec 12, 2017 | Singer Sewing Machines
Needle will not pick up the bobbin thread.
Could the needle be inserted incorrectly? Typically, the flat of the needle shank goes to the back of the machine. Are the needles the correct type for your machine?
Mar 25, 2014 | Singer Featherweight 132Q Mechanical...
Am considering buying a used Singer Featherweight 132q. Have been trying to find any problems that this model may have but have not been able to find anything, Please help.
I've been sewing for over 30 years,, my suggestion is,, let them sew on the machine so you can watch,, & even ask to sew yourself,,, let them show you what the machine can do.. they should be willing to demonstrate the stitches & anything else the machine can do.. ask questions like has the machine got any problems,, has it been resently been serviced,, does it have a operation manual with it,, has it been well taken care of? are there any scratches on it? are there any burrs around the needle plate,, use your fingers to rub over the needle plate to see if it's smooth or not,, even check the small area in the needle plate where the needle goes down to meet the bobbin... have they ever broke a needle sewing? that can cause the machine to go out of time..
good luck
Feb 11, 2012 | Singer Sewing Machines
I cannot remember how to insert a new needle since I have just broken the last one! Please help!!
usually the needle have a flat side which goes toward the back of the machine & inserted all the up into the needle holder
Sep 05, 2011 | Singer Featherweight 132Q Mechanical...
My bottom stitch is "loose"
You might try adjusting your bobbin. You can do this with a tiny flat head screwdriver. Adjust in very small increments! There is a screw located on your bobbin case.
Here is the info directly from the manual:
"To test if the bobbin thread tension is correct, suspend the bobbin case by the thread and **** it once. Correct bobbin tension will result in the thread unwinding by only one or two inches. If too loose it will unwind continuously. If too tight, the thread will not unwind at all. When adjusting the tension on the bobbin case, make only slight adjustments with a screwdriver."
That is usually the cause of garbled up threads on the bottom side. Sure hope this helps!
(The 132Q is my third Singer, but will be my last. It's been a nightmare to deal with, and ALWAYS has something going wrong with it. I can never just sit down and do a project.... it is like the settings never stay put. There is also a LOT of plastic inside this model, and it cracks, breaks, warps, etc. We've replaced plastic gears/parts with metal parts, and it still acts up. Just a lemon model!)
Nov 05, 2010 | Singer Featherweight 132Q Mechanical...
Bobbin won't pick up
the problem is, your needle so short, adjust your needle bar down, so that the thread of your bobbin will come out.
Sep 29, 2009 | Singer Featherweight 132Q Mechanical...
Inserting needle on old singer machine
Hi Terry--
If your machine is 40-50 years old, it might be a Singer Featherweight portable. (If it is, you have one of the very best machines ever made!) On the Featherweights, the flat of the needle faces left (and the needle is threaded from right to left). The bobbin goes in a bobbin case; you'll see a small notch when you look down on the bobbin in the case. That's where the thread goes. I'll email you direct with more information.
Lookingpast
Dec 26, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer Featherweight 132Q Mechanical Sewing Machine Logo
239 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
