I have a 42 inch Samsung Plasma model #HP R4252 and I have no picture. I got this Tv from a friend of mine and he said that he had sound but no picture. What is wrong??
  • 6 more comments
  • ccarr123494 May 12, 2009
    if I was looking at the back of the tv what does the LCD inverter look like
    How can I test my SMPS to see if its working??
    I have power on the power supply.. how can i check the x inverter? There isn't a PCB on the top of my TV only the bottom and one on each side
    I have a 42 inch Samsung Plasma HDTV model #HP R 4252. I have sound but no picture can anyone help me run a check on it? What should I check what reading should I be getting?
  • ccarr123494 May 13, 2009
    Where can I check the voltages for these??
  • ccarr123494 May 18, 2009
    Hi, ZI have a 42 inch plasma that was given to me. The model #is Hp R 4252. I had sound but no picture. I replaced the Y lower buffer but that did not fix it. What could be wrong with this? 9 dollars to whoever helps me!!!
    Yeah.. I already spent a 100 bucks on the dam y buffer which WAS bad, but I still have no picture and the tv comes on and all, but I just don't have any picture. How can i test some of this stuff?
  • ccarr123494 May 19, 2009
    I haven't I dont even know where that is. I did check the voltage at VS and Va. I had 50 VDC at Vs and wasn't reading anything at Va. The Tv powers on, I have sound but I have no picture can you help??? Also, when i unplug the Smps from the main ps board, thats the only way i cna hear the sound...? I'm an electrician not a tv repairman, I can do the leg work, i just need direction
  • 103 Answers
Have you already ruled out the lcd inverter?
Posted on May 19, 2009
  • Tyson Strickland
    Tyson Strickland May 19, 2009
    Take a flashlight and with the tv on shine the light on the tv and see if you can see anything on the screen. You can sometimes also look from a different angle and see the picture if the lcd is burned out.
  • 11,896 Answers
If it is a flat panel tv, than it is most likely the CRT's or IC's that will need to be replaced. That is color picture tubes or capacitors on video board. You will have to purchase a repair manual to change the caps. Otherwise I suggest having it repaired by tech. I believe it is worth having it repaired since it is newer.
Posted on May 18, 2009
  • 916 Answers
This means that either the X-sus, Y-sus or the Z-sus board isn't powering up the pixels and one of them needs to be replaced. To test them you can open the back of the tv and use a multimeter to check the voltage.
Posted on May 13, 2009
  • 15,935 Answers
Your LCD power Supply has failed.
Cost to replace (depending on stock) is about $400.00 about $150 for the part and the rest labor.
Thanks for using FixYa!!
Posted on May 12, 2009
  • 2 more comments
  • blueextc3221
    blueextc3221 May 12, 2009
    If you're feeling froggy - remove the back panel and look for scorching on the Y Buffer board.
    There are 2 in the unit - upper and lower - if one is damaged - usually backfeeds and causes damage in both. Both will need replacement.
    If there are no error indicator flashes though - the LCD power supply is the likely culprit.
  • blueextc3221
    LCD Power supply/Invertor board:
    LCD TV invertor:
    Invertor only has ICs and diodes (basically)
    Power supply has caps, coils, fuses & more
    Some TVs (as pictured above) have 2-in-1 power supply/invertor board.
  • blueextc3221
    here is the y invertor board i was speaking of too -
    There are 2 (different part #s as well) Upper and Lower.
    If you are going to attempt a repair - a $20 service manual will do you a LOT of good in determining the locations of the parts and the troubleshooting thresholds.
    Thanks!!
  • blueextc3221
    your switching mode power supply shouldnt need testing - there is power - or there isnt.
    Start with the fuse and work your way back.
    In order to fully test ICs and some other components - you must de-solder from the board to test.
    The Service manual will give you all the voltage specs at each designation.
    HELPFUL LINK
I was given two 42 inch plasma TV's for free, but they both have sound and no picture. 1 is a Sylvania model 6842thg a and the other is Samsung hp r4252 made in 2005. Please help me because I really like...
Maybe you just figured out why they were given to you for free. If you have some electronics knowledge, you can open them up and look for blown fuses or burned components and replace them. Otherwise, it's not usually worth repairing a 12 year old plasma TV.
Aug 28, 2017 | Samsung Televison & Video
Samsung hp-R4252 can you remove the soundbar, for appearance reasons? Just hook up sound through stereo?
no the sound bar is not removable unless you cut it off i would suggest steping up to a new led tv great for picture and mounting on the wall ultra thin this tv got really poor reviews
Jan 06, 2011 | Samsung HP-R4252 42 in. Plasma HDTV
I Have a Samsung HP-R4252 42 in. HDTV Plasma Television and the picture is not showing. It does have sound but no picture. Is there any ease way to fix this problem??
sounds like the video cable is not in the right input.
or maybe you have to redo the setup and be sure the tv is set to the right video input . HDMI or component etc. I hope this helps.
Oct 19, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
I have a 46 inch Samsung plasma HP R4252 picture went black
Probably the power supply that drives the video has gone bad. Samsung recommends the TV go to a service center. If you have some skill and are willing to try, open up the back of the TV, remove the shielding and look at the boards to identify any obvious damage. Leaking or bulging capacitors, soot, scorch marks are the obvious. (Other parts can have bad solder or tiny cracks that are hard to spot.)
http://www.shopjimmy.com/catalogsearch/result/index/q/HP-R4252 has reclaimed parts for this TV. These are parts from TVs that were damaged in shipping and were only run during quality control tests. They list several power supplies for the model so check what part number is actually installed (there is usually a label on the board).
I hope this helps.
Aug 01, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
I have a samsung HP-R4252 42" Plasma which is over 3 years old and 3/4 of the picture is covered in lines and the color is predominately red, any help?
REPLACED Y BUFFER BOARD
Samsung BN96-02034A BOARD, Y BUFFER UPPER ASSY
Samsung BN96-02216A BOARD, Y LOWER BUFFER ASSY LJ92-01203A
Nov 02, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Hp r4252 white vertical stripe on left side, 5 in wide
Well sound as if a segment or Ic driver has failed on the panel. And a 42 inch replacment panel can run you $1250.00
Jan 30, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
R4252 No picture, sound OK Y-Drive buffers overheating
Try to replace the Logic Board, about 50% chance to fix the problem.
Jan 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
