Question about Toro Lawn Mower With Toro Power Tools
Very little grass is shooting into the bag to fill it
No previous problems but now the grass isn't shooting into the grass bag. It's not stuck in the way, it's just not going into the bag. Nothing lookings broken. The motor is running good. It happens even when cutting the grass high.(therefore not really a clumping problem) My sister in law having the same problem with her toro. Lawnmower repair guy says grass is wet and happens, but should this be happening on 2-3 day without rain grass. Any suggestions
  • 246 Answers
Hello monica_skinn:
If the Underside of the Deck is Clean and the Blades are Tightened Properly, then the Problem is Caused by the Blade Lifts being Worn or the Blades are Not a High Lift (Bagger Blade) Blades.
A Bagger Blade has a Very High Lift Ear on the Backside of the Blade Across from the Cutting Edge. This Extra Lift is What Gives the Extra Lift and Throw (by increasing air Flow under the Mower) the Grass gets to be Bagged.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
Cutting grass but it isn't going into the bagger?
grass catchers need special shaped or good blades to throw the cut grass into the bag
check/ replace the blades
May 06, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Shoot to the bag plugs and then only muches. Will only bag minim al length
sounds like your grass is too wet for the machine you are using.. Dry gras should not plug unless it's too long as well.
Sep 22, 2014 | Garden
Can I fill my punching bag with grass?
I would advise against this. Grass will not pack very well and eventually will begin to smell.
Aug 07, 2012 | Boxing
Mower is not shooting the grass out when using the mulcher. I have to clean the grass out when cutting the grass.
Maybe the grass you are trying to MUCLH is a little too high. Mulching doesn;t really cause the machine to "shoot" out the grass the way conventional cutting with a conventional blade does....it is the type of blade that when spinning, creates air pockets under the deck that allow the blades to keep cutting the grass over and over. Switch to a different blade to get it to shoot out.
Aug 13, 2010 | Black & Decker Garden
Husqvarna clogging problems
make sure your deck is scrapped out after every 8-10 mows, make sure your blades are sharp. I'm assuming you have a bagging system. Make sure you have the correct blades on your mower. Blades need to have a high wing in order to push the debris out correctly and make sure there are no other obstructions in shoot and always run engine at high rpm.
May 13, 2010 | Garden
Grass collector not filling
HMM .. if the grass is not going into the collector, I would look under the deck and see if there is something blocking the chute to the bag.
Please vote !!
May 12, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Can my lawn mower turn into a mulcher? it has a bag which fills up too quickly and we need to know if we can lose the bag or are we stuck with it? trust me, there is no flap or anything like that from the...
When you take off your bag isn't there a flap that slams shut over the hole? If there isn't then you're stuck with it.
Depending on the make, some mfgrs make a mulcher kit with special blades and a chute blocker.
The downside of mulchers is having to mow really dry grass twice a week or you'll have clumps of green glop all over the yard.
Aug 31, 2009 | Garden
Lawnmower dosent bag grass correctly(leaves clumps of grass behind) also doesnt seem to have the power it once did.Not sure whats up.
there is a little do dad that fits in the hole that the grass is suppose to come out of called the rear mulching baffle that blocks the hole to the bag... remove it and shuld be ok
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Stuck in high position
On this model vehicle the rear shockers should have air bags to keep car at normal ride height, when load changes.
The air bag can sometimes become caught between inner and outer tubes of shocker when car is raised and lowered quickly.
You will need to jack car up from tow hitch or frame to lower rear axle, this will unfold air bag, slowly lower car, with ignition on, this will make sure air compressor is filling air bags as they take the load.
Hope this is helpful, MMP
Aug 09, 2008 | 1995 Lincoln Continental
Toro Lawn Mower With Toro Power Tools Logo
438 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
