Sometimes it will drive fine, than it will just start stuttering like it wants to die.
SOURCE: STUTTERS DURING ACCELERATION
throttle position sensor .. this lets the computer know just where your foot is on the gas .. It gets worn out in that position because that is where it is used the most. I would check it first then go from there... they are priced reasonable .. always start with the least expensive first then go from there. thanks Jerry holler if you need more
SOURCE: engine stutter in drive
two things may cause this stuttering. 1) worn or severed engine mounts and or pours or leaking high tension leads spark plug wires
SOURCE: engine stuttering upon acceleration
Sounds like your transmission is shot... but I'm not sure... Generally when you have problems while shifting gears it's the tranny isn't it? I'd get it looked at.
SOURCE: 99 Buick LeSabre stutters on acceleration, any
First thing I would do is change the fuel filter and air filter
SOURCE: Need help with 2001 Toyota Corolla stuttering!
CHECK ENGINE COMPRESSION BETWEEN COLD AND HOT , DURING ENGINE IS COLD SOME VALVE IS NOT SEALING MUCH .
