Question about Quinny Buzz Three Wheel Stroller
Adjustable Foot Rest
Hi there
i have a problem with the adjustable foot rest it will not
adjust its just floppy and is hanging can you suggest
what i should do, it was brand new when i bought it and it adjusted into
different positions now it wont?
thank you
ann
    Problem Solver:
  • 5 Answers
It may still be under warranty so the store you purchased it from can help
Posted on Aug 14, 2009
Model 60-7000M. All works except foot rest. It will not close. Help!
Not sure what you mean by foot "rest." If it is presser foot, then you may not have the correct presser foot for your machine (basically, there are 3 types--low shank, high shank, & slant shank). Usually, there is also a pressure adjustment for the presser foot that increases the amount of pressure applied to the fabric and feed dogs. Consult your owner manual. Pressure adjustment is usually either a dial, a plunger type on the top left of the machine (pushing down increases the pressure--push down on the outer ring to release it), or a screw at the very top of the presser foot bar (sometimes under the top lid).
Dec 29, 2016 | Sewing Machines
How to adjust tension on foot-rest?
Consult your owner's manual. Most machines have a presser foot pressure adjustment. On older machines it is usually a pop-up button directly above the needlebar, on others it is a screw. Newer machines will have a dial.
Jan 26, 2016 | Sewing Machines
Show me how to use this zipper foot. I am having problems
Here is a video on using an adjustable zipper foot:
How to Use an Adjustable Zipper Foot
If this is not the correct foot for your machine, do a YouTube search and you will most likely find a video that will be helpful.
Sep 18, 2015 | Sewing Machines
Why foot will not depress enough
Presser foot pressure is adjustable. Open the head cover and look for the presser foot shaft behind the light. On most models there is a spring around the presser foot shaft that pushes on a collar. The collar is adjustable (higher up pushes down more) and held on with a socket head screw (use a hex wrench).
Jan 11, 2015 | Sewing Machines
I had anew clutch in the hyundia in 2010 it seems to be slipping how long should it last can it be adjusted
Clutch life is determined by several factors, most of which you have control over. Excessive revs while slipping the clutch to move slowly, resting you foot on the clutch pedal instead of the foot rest, starting to move in 2nd instead of 1st, allowing the vehicle to run back when engaging the clutch to go forward. Assuming you do not do any of these things then it comes back to the clutch master cylinder being faulty and a compensating port is blocked and holding the clutch partially disengaged. The clutch is not normally adjustable. I would check the condition of the fluid and if it is almost black I would replace the m/cyl. Find out if the m/cyl has been replace if possible
Feb 01, 2013 | Hyundai Cars & Trucks
When I attach my embroidery unit to my babylock ellagio, the screen say to rasie the presser foot....but the foot is already raised? Any suggestions??
Try lifting it past the point it would normally rest at, in the up position. Then if the message comes up touch okay. It sould recalibrate the unit when its lifted. It may be able to be adjusted, mostly its a replacement. The switch is at the back of the machine in above the presser foot. You can see if the back cover would come off.
Derek
Jan 21, 2011 | Sewing Machines
I misplaced my ktm adjustable rear set manual, how...
the gear shifter and the brake pedal should be set even with the footpegs.. the same height so when you rest your foot on the peg it should be right on top of each.. hope that I could help
May 16, 2010 | Motorcycles
Foot rest not locking on quinny buzz
You need to buy the foot rest adjuster set £20 + 3.99 from Dorel UK 01842 763 281 (Mon – Fri, 8:30 am to 4:30 pm) They are the sole supplier of parts for Quinny.
Apr 12, 2010 | Quinny Buzz Jogger
Jig Saws Adjustable foot
An adjustable foot is the metal plate at the bottom of the saw which will pivot between 0 and 45 degrees. This will allow you to make angle cuts in the wood
Aug 27, 2008 | Porter Cable Cable 53530 Edge Guide for...
Quinny Buzz Three Wheel Stroller Logo
106 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
