Question about Brother MFC-5460CN All-In-One InkJet Printer
Fax problem need help setting up fax to my pc
  • pebie Dec 30, 2007
    i cannot get this to work keeps telling me to reinstall mfl-pro suite
  • 832 Answers
I guess you run win xp.
Did you install the whole mfl-pro suite? If not, do so. Check the installation by clicking installation check within the brother programm (start/progr./brother/installation check).
After a good installation press start/progr./brother. There you will find a pc-fax set-up. With that you can fax out of your pc thru the mfc.
If you want to receive fax on your pc you have to change settings within the machine . see handbook software which is part of the installation software cd how to do the right settings (chapter I 6 pc-fax)
Posted on Oct 14, 2007
Fax connection
To send a fax, you will have to configure the settings. here are the steps you can follow;
Remote Fax Options;
You can only use one remote fax option at a time:
Fax Forwarding—OR—Paging—OR—Fax Storage—OR—PC FAX Receive—OR—Off.
You can change your selection at any time (Menu/Set, 2, 5, 1).
Setting up Fax Forwarding
When you select Fax Forward, your MFC stores the received fax in the memory. The MFC will then dial the fax number you’ve programmed and forwards the fax message.
  1. Press "Menu/Set, 2, 5, 1".
  2. Press ▲ or ▼ to select "Fax Forward". Press "Menu/Set". The LCD will ask you to enter the fax number to which faxes will be forwarded.
  3. Enter the forwarding number (up to 20 digits). Press "Menu/Set".
  4. Press ▲ or ▼ to select "Backup Print:On or Backup Print:Off". Press "Menu/Set".
If you select "Backup Print:On", the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is forwarded.
5. Press "Stop/Exit".
Programming your pager number When Paging is selected, your MFC dials the pager number you’ve
programmed, and then dials your Personal Identification Number (PIN). This activates your pager so you will know that you have a fax
message in the memory.
1. Press Menu/Set, 2, 5, 1.
2. Press ▲ or ▼ to select Paging.
3 . Enter your pager phone number
followed by # # (up to 20 digits). Press Menu/Set.
Do not include the area code if it is the same as that of your MFC. For example, press 1 8 0 0 5 5 5 1 2 3 4 # #.
4. If your pager needs a PIN, enter the PIN, press #, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press 1 2 3 4 5 # Redial/Pause 1 8 0 0 5 5 5
1 2 1 2 # #) —OR— If you do not need a PIN, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press Redial/Pause 1 8 0 0 5 5 5 1 2 1 2 # #)
5. Press Stop/Exit.
■ You cannot change a Paging number or PIN remotely.
■ If you have set Paging, a backup copy of the received fax will
automatically be printed at the MFC.
Setting Fax Storage
If you select Fax Storage, your MFC stores the received fax in the
memory. You will be able to retrieve fax messages from another
location using the Remote Retrieval commands.
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
Setting PC Fax Receive
If you select PC Fax Receive, your MFC will temporarily store your
received fax messages in its memory, and then automatically send
the faxes to the PC. You can then use your PC to view and store
these faxes.
PC Fax Receive.
Press Menu/Set.
3 Press ▲ or ▼ to select
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
If you have turned on Fax Storage, a backup copy will
  • Before you can set up PC Fax Receive you must install the
MFL-Pro Suite software on your PC, make sure your PC is connected and turned on. (For details, see Using Brother PC-FAX software on page 5-1 in Software User’s Guide on
the CD-ROM.)
  • If you select Backup Print:On, the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is sent to the PC.
■ If you get an error message and the MFC cannot print the faxes in memory, you can use this setting to transfer your faxes to your PC.
Turning off Remote Fax Options If you set the Remote Fax Options to Off and there are faxes in your MFC’s memory, the LCD will give you two options.
  • If you press 1, all unprinted faxes will be printed and erased
before the setting turns off. If a backup copy has already been
printed it will not be printed again.
  • If you press 2, the memory will not be erased and the setting will be unchanged.
Setting your Remote Access Code
The remote access code lets you access the Remote Retrieval features when you are away from your MFC. Before you use the remote access and retrieval features, you have to set up your own code. The default code is inactive code (--- ).
  1. Press Menu/Set, 2, 5, 2.
  2. Enter a three-digit code using numbers 0-9 or . Press Menu/Set. (The preset ‘ ’ cannot be changed.)
  3. Press Stop/Exit. Do not use the same code which is set in your Fax Receive Code ( 51) or Telephone Answer Code (#51). You can change your code at any time by entering a new one.
  4. If you want to make your code inactive, press Stop/Exit in Step 2 to restore the inactive setting (--- *).
May 05, 2009 | Brother MFC 7420 All-In-One Laser Printer
HOW DO I SEND A FAX ON THE BROTHER MFC-5440CN? LOST MY MANUAL
Remote Fax Options;
5. Press Stop/Exit.
Setting Fax Storage
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
these faxes.
PC Fax Receive.
Press Menu/Set.
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
the CD-ROM.)
Apr 22, 2009 | Office Equipment & Supplies
I want to set up my fax on my printer to fax in and out
hi does your printer have an phone sockket on it cable need, fax software and installation -setup fax
most printer will need seting up on pc you can fax from pc with a rj11 on it
Dec 04, 2008 | Computers & Internet
Faxing
You need Option, AR-FX7 (FAX) installed, real easy to figure out, look at the side, if you see a telephone line, with line and telephone connections (not the Network connection) then you have a fax.
Next your arm237 will also need to be able to print from the nextwork.. if this is all together..
you will need a driver called, PC to Fax for the AR-M237.
which you can find at www.sharpusa.com
Then you will have to set up the computer in the printer folder to PC to Fax.
Sep 29, 2008 | Sharp AR-M237 Copier
SET UP
CONNECT POWER CODE TO FAX
ALSO CONNECT TELEPHONE LINE TO ITS POSITION.
THEN RESET YOUR FAX TO DEFAULT SETTINGS
SET AUTO RECEVING .
ALSO IF U HAVE PC WITH MODEM U CAN SEND AND RECEIVE FAX FROM IT.
IF U NEEDD ASK ME.
BYE
Mar 24, 2008 | Lexmark X4270 All-In-One InkJet Printer
Receive fax on the fax system as well as your PC
If you change the number of rings on the fax machine to more than on your PC, your PC should receive the fax first and accomplish your goal.
Dec 19, 2007 | HP LaserJet 3500n Printer
Receiving Fax on PC
no the fax machine is designed to print any recieved faxes as it recieves them.
it will not save faxes to computer instead of printing them out
Nov 25, 2007 | Samsung CLX 3160fn All-In-One Printer
Unable to init.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. ?OR? A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. ?OR? You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. ?OR? To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 06, 2007 | Brother MFC-5840CN All-In-One InkJet...
Printer problem
MFC 5840cn - lcd shows 'unable to print see troubleshooting and routine'
Aug 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5460CN All-In-One InkJet Printer Logo
131 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
