Question about Dell Latitude D510 Notebook
I have a micro sd adapter and I do not know where to insert it into the laptop
    President:
  • 2,559 Answers
You do not have an sd card slot on that computer,You will need to get a USB sd card reader.
Please take time to rate this fixya
Posted on May 11, 2009
I WOULD LIKE TO HAVE A MANUAL FOR INSTRUCTIONS ON HOW TO INSERT MY MICRO SD CARD INTO MY COMPUTER AND WHAT TO DO WHEN I INSERT THE MICRO SD CARD
You'll need an adapter to convert the Micro SD card into a normal size SD card, slot the Micro SD into the SD card adapter and then plug that into the computer.
Most computers then pop up a box to tell you that you've plugged something in, so you can then browse what is on the card.
Double clicking on the items on the card will then enable you to view the images/items.
Aug 16, 2016 | Cell Phones
Micro sd card too big for garmin gps nuvi 1450
A micro SD card is the correct memory card for the 14xx series. A 2 GB should be just fine. Some units can not handle a large memory SD card. This has nothing to do with the physical size however.
Are you sure it isn't a micro SD card that is inserted into a standard SD card adapter? A standard SD card is much larger and will not fit into the 14xx series. Look at the end of the SD card that does not have the gold pins and see if there is a ridge where the micro SD card may be inserted into the larger standard SD adapter. Using a fingernail, you can slide the micro SD card out from the SD card adapter. Also, the micro SD card will only insert one way. Try flipping it over and inserting it again, always with the gold pins facing the Nuvi.
Apr 06, 2013 | Garmin nuvi GPS
My lg pop wont read the memory card , and my other phones all read the memory card, no matter what memory card i insert to the lg it says" format memory card" then i do and still nothing, could...
I had the same problem with an HTC Aspire ( I think that's what it was called :} Anyway I formatted the micro SD card in fat 32 through my laptop using a micro sd to sd adapter and the sd card slot on my laptop. I then stuck the micro sd card back into the HTC and it worked. I heard formatting through another phone works too. Try it and let me know.
Nov 07, 2011 | LG GD510 Cell Phone
WHERE DO I PUT THE SD ADAPTER
Hello.
You don't need the SD adapter in your mobile phone. You may use it by inserting the micro SD card into the SD adapter, then insert the SD card adapter in a "SD card reader" and use it in a USB slot in your computer to access files from your "micro SD card".
I hope this helped you.
Thanks for using Fixya!
Please rate my answer.
Aug 04, 2011 | HTC Hero Smartphone
Emachine laptop E627
I think you are telling about the adapter if you are trying to insert a micro sd card then insert the card in the adapter and then try to insert it in the slot if you are using a big sd card then directly insert it in the slot.
Feb 03, 2010 | Acer eMachines 520-2890 Notebook
Insert memory card
I am assuming you are trying to read a SD card from a phone or a sim card. If it is an SD card it will be a micro SD. You will need an adapter to make it a full sized SD card and then it will in the card slot on your laptop If it is the sim card you would need a special machine for that and there is nothing there but the phone's codes anyway. You should be able to find a cheap micro SD card at CompUSA - I think about $6 - $8, and it should come with the adapter.
JC
Nov 17, 2009 | Compaq Presario M2000 Notebook
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
How do i transfer pictures from cell phone to laptop?
two known options:
-email photo to yourself from the phone.
-this phone seems to have a micro sd card slot - you can insert a micro-sd card and transfer the photos to the card, then read the card on the laptop with a reader that supports micro sd.
so, you should check into the laptop and see if it has any card readers built in since you may need an additional adapter or device in order to connect the micro sd card to the laptop.
some micro sd cards will come with adapters to the larger sizes of mini and standars sd card, which may help.
you might also have luck putting the card from the phone into some other connectible device (ie a camera) and move the files in that manner - but depending on your hardware and software this may not be a viable option (inexpensive to try, though, if you already own some compatible device)
Nov 01, 2009 | LG RUMOR Cellular Phone
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
I dont know where to put this
Hi, First insert the micro SD into its adapter which resembles a SD card itself but has a small opening at the bottom to insert the micro SD. The adapter should not b locked while inserting or removin the micro SD. Now insert the adapter in the card readers slot which should be connected to a PC via a USB. If its a card reader then insert the adapter with microSD in the right side top corner of the card reader with the adapters copper pins facing down. OR if u already have slots in ur CPU to insert the SD card install it there, Now transfer files to ur card happily. NOTE: Rename ur device so that next time when u plug it in the adpter n connect it to PC, u wont get confused. Just right Click on the drive icon in ur PC n select rename n just giv any name as u lik. Rate he soln dude Bye..........!
Jan 25, 2009 | PNY 2GB microSD Memory Card
Dell Latitude D510 Notebook Logo
197 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
